flatcat19 Posted October 22, 2012 Report Share Posted October 22, 2012 SoCalDatsun put some on his. He had different wheels-but had slight fitment issues. http://community.rat...bie-oics-added/ Look good? Yes. Work? Sure. Better option? Meh. Your truck. Your money. Your call. Quote Link to comment
chebetio510 Posted October 23, 2012 Author Report Share Posted October 23, 2012 thanks was lookin at the thread dont want to end up with spacers.. . might just go with the hardbody calipers,.. on another note..Pics,,, Got 720 leaf springs... for More drop The camper shell, not sure but have a felling its too small.. :( Quote Link to comment
71kat510 Posted October 24, 2012 Report Share Posted October 24, 2012 http://datsunminitruckin.com/ka24de-swap-into-a-620_topic1051_page1.html Quote Link to comment
flatcat19 Posted October 24, 2012 Report Share Posted October 24, 2012 http://datsunminitruckin.com/ka24de-swap-into-a-620_topic1051_page1.html WHAT THE FUCK IS THAT SHITE!?! Bad, n00b. BAD! Quote Link to comment
chebetio510 Posted October 31, 2012 Author Report Share Posted October 31, 2012 got the motor and transmisison in this sunday on my day off.. it really is easy with @Redeye's mounts... here are some pictures. Quote Link to comment
chebetio510 Posted October 31, 2012 Author Report Share Posted October 31, 2012 A bit confused on driveshaft, the stock 620 driveshaft fits the ka trans, not sure if need to cut off some of the yoke surrounding to have it go in the transmission more to get an accurate measurement for front shaft shortening? Quote Link to comment
]2eDeYe Posted October 31, 2012 Report Share Posted October 31, 2012 I believe you will need to cut that off anyways if you are using the KA transmission. Hopefully someone will verify. Quote Link to comment
chebetio510 Posted November 1, 2012 Author Report Share Posted November 1, 2012 hopefully redeye your mounts are dope the engine went in with such ease Quote Link to comment
]2eDeYe Posted November 1, 2012 Report Share Posted November 1, 2012 Thanks, glad you like them :cool: Quote Link to comment
CameronT Posted November 4, 2012 Report Share Posted November 4, 2012 Man I love the projectors with the eyelids, I like the idea might do it but I think instead of yellow, might go with possibly a set of blue for brights Quote Link to comment
Project Bandwagon Posted November 6, 2012 Report Share Posted November 6, 2012 i was going to try and help with the driveshaft measurement, then i remembered i swapped the 240 IRS in Quote Link to comment
chebetio510 Posted November 6, 2012 Author Report Share Posted November 6, 2012 -_____- lol thts still pretty sick.. lol wouldnt mind doing tht if i knew how to weld.. Quote Link to comment
chebetio510 Posted November 16, 2012 Author Report Share Posted November 16, 2012 So picked up this grill and Spoiler at the Eagle Rock swapmeet.. test fitting looks good.. working on the truck's wiriing and im a bit lost.. how to make the ka alternator work.. i dont have the lower harness for the ka so don't ahve that plug.. Also, starting the motor, am i using the original starter wire from the 620 ? was looking at Icehouse's can am diagram and it say's to use a orange wire for starter? do i combine that wire with the orginal 620? Quote Link to comment
chebetio510 Posted November 16, 2012 Author Report Share Posted November 16, 2012 also since i don't have lower harness.. knock sensor not hooked up? Quote Link to comment
banzai510(hainz) Posted November 16, 2012 Report Share Posted November 16, 2012 PM Redeye on here. Icehouse did his he might be able to awnser that one or loook at his setup. I believe the orange goes to the ECU box to signal something going by memory. But yea use the starter wire. and combine them I would think. But ask to be sure. But be better if you put that in drawing. Or you could just find the hot start wire and splice it from there if this was a Point ignition truck. Lower harness for the KA? Why dont you go to the Junk yard or even NAPA might have the plug and you can make a nice jumper from the old 620 harness to the KA plug. Datzenmike has a photo of this I believe he made. whatever you do dont let the last guy wire the truck like your 510. We all know what happen to a car that was running 40years perfect. Quote Link to comment
]2eDeYe Posted November 16, 2012 Report Share Posted November 16, 2012 The starter is run by the truck system, much like the alternator. The orange is for the ECU to tell it what is going on. Not sure on the lower harness, but you should be able to wire in the sensor and get the correct harness later. Quote Link to comment
chebetio510 Posted November 16, 2012 Author Report Share Posted November 16, 2012 I'm doing the wiring on my own this time lol. He isn't, I thought the lower harness was really needed for the knock sensor, and and other plugs, the alternator I wasn't to worried about.. I will pm him, Quote Link to comment
chebetio510 Posted November 28, 2012 Author Report Share Posted November 28, 2012 guys whats the best way to get the driveshaft measurement for the motor swap.. ? to line up the center carier bearing.? Quote Link to comment
]2eDeYe Posted November 28, 2012 Report Share Posted November 28, 2012 Which transmission are you using? If you are using the KA trans, you will need to bolt up the rear portion of the drive shaft and carrier bearing mount. Measure from the center of the drive shaft flange to the center of the trans output. This will tell the driveshaft shop how long to make the front section of the shaft. Make sure to tell them how you got the measurement so they can account for the slip yoke. Quote Link to comment
chebetio510 Posted December 30, 2012 Author Report Share Posted December 30, 2012 got most of the wiring done today.. was going to test start.. but got motor to crank once and starter went out.. the starter had been sitting for a while.. wasnt sure on the condition.. fuel lines are in..... working on the center link.. was using the 3/4 step drill but seems to have become dull.. it wont cut anymore... so will try to get a new bit.. Quote Link to comment
chebetio510 Posted January 7, 2013 Author Report Share Posted January 7, 2013 yay got the truck started cooling system not done yet.. but luckily i know it will start.. gavin a slight issue though.. starts fine but shuts off almost instantly unless i accelerate the engine. it rev up fine but as soon as u let off it dies... It does not have the intake done yet... does the MAF sensor not being hooked up make tht big of an impact.. ? Quote Link to comment
]2eDeYe Posted January 7, 2013 Report Share Posted January 7, 2013 Yep that will cause some problems. Good to hear you got it to fire :D Quote Link to comment
chebetio510 Posted January 8, 2013 Author Report Share Posted January 8, 2013 Yep that will cause some problems. Good to hear you got it to fire :D Yep that will cause some problems. Good to hear you got it to fire :D yup i am glad also.. man everything is tight in there.. lol looks like the stock speedometer will work length wise Quote Link to comment
]2eDeYe Posted January 8, 2013 Report Share Posted January 8, 2013 You will want to run the cable over the transmission under the floor instead of trying to keep it in the engine bay. Quote Link to comment
Hermistonkilla Posted January 8, 2013 Report Share Posted January 8, 2013 No pictures??? Quote Link to comment
