kiznook Posted April 28, 2007 Report Share Posted April 28, 2007 Getting ready to do the energy stuff on the 510, looks like i need to have the stock bushings pressed out?? (yes that is a question :D) Quote Link to comment
slodat Posted April 28, 2007 Report Share Posted April 28, 2007 NO!! You have to burn out the rubber with a torch and then cut the sleeve with a hacksaw until you just cut through it. Then, you can pop it out. Many people have bent the arm attempting to press it out. Quote Link to comment
BEEBANI Posted April 28, 2007 Report Share Posted April 28, 2007 Yep, same thing on the 620's. There's just no better way. Quote Link to comment
kiznook Posted April 28, 2007 Author Report Share Posted April 28, 2007 same for front and rear? I think i'll get started on it tomorrow Quote Link to comment
slodat Posted April 29, 2007 Report Share Posted April 29, 2007 Yes, same for front and rear. It's a pain in the ass to do it. I have to do another set of rear control arms myself. You can avoid the front by putting heim joints in! Quote Link to comment
kiznook Posted April 29, 2007 Author Report Share Posted April 29, 2007 Yes, same for front and rear. It's a pain in the ass to do it. I have to do another set of rear control arms myself. You can avoid the front by putting heim joints in! yeah, probably will someday...likely next winter Quote Link to comment
Icehouse Posted April 29, 2007 Report Share Posted April 29, 2007 Yes, same for front and rear. It's a pain in the ass to do it. I have to do another set of rear control arms myself. You can avoid the front by putting heim joints in! I want to put heims in the rear to :D Rubber sucks and in my opinion so does polyurethane does to. I had a rear crossmember slotted with polly and it wore out within a year. I know it binds but the rubber will last longer. Quote Link to comment
