ricopico5 Posted October 15, 2012 Report Share Posted October 15, 2012 I am converting my Datsun 521 from a 4 speed to a 5 speed. I have the trans, now am in need of a 1 piece drive line. I hear it comes out of a 720 pick up.. Anyone?! Please get back to me if you have 1. Quote Link to comment
datzenmike Posted October 15, 2012 Report Share Posted October 15, 2012 Well what 5 speed? The dogleg will fit without changing the 521 driveshaft. If a 620 or Z car 5 speed there are some 720s that had a one piece driveshaft but never heard it will fit without shortening so why not just shorten the one you have? Quote Link to comment
wayno Posted October 15, 2012 Report Share Posted October 15, 2012 The driveline depends on which 5 speed you have, is it 26 inches long or 31 inches long? You will also have to make a differant transmission mount, as the stock one will hold the 5 speed to high and it will likely hit the tunnel. Quote Link to comment
DanielC Posted October 15, 2012 Report Share Posted October 15, 2012 I have a long 5 speed in my 521. I got the proper yoke for the five speed, a slip yoke, and had the front section of the drive line shortened, and the correct yoke, put on the front U-joint. Yes, I had to make a shorter rear mount for the transmission. Quote Link to comment
Tucson620 Posted October 15, 2012 Report Share Posted October 15, 2012 I have a 620 long tail 5 speed in my 521. I pieced together the driveshaft from a 620 front half and 620 carrier bearing, then the 521 stock pieces from there back. I think Hessianben's thread pioneered that solution. And I had to make shorten my rear tranny mount too. The result is the slip yoke has a about 1.5 inches less engagement, but it's workable. Had to move the shifter hole back 5 inches or so - still clears my seat fine. Made a custom plate to replace mine. Install of engine/transmission combination is tough in a 521. I installed separately - still learned plenty of lessons. Quote Link to comment
ricopico5 Posted October 15, 2012 Author Report Share Posted October 15, 2012 thanks four info Quote Link to comment
Tweeker521 Posted October 22, 2012 Report Share Posted October 22, 2012 I got a two piece on myne with a 5 speed Quote Link to comment
