AcesHigh Posted October 11, 2012 Report Share Posted October 11, 2012 After doing a reverse flush, the radiator still overheats so I took it into a radiator shop. They said the core is bad, and since the radiator isn't stock and it can be re-built for $300. Would a 510 or 620 radiator bolt right in? I heard I could use a Pontiac Fiero radiator but it would require adapters and hoses. Thank you for your help! Quote Link to comment
DanielC Posted October 11, 2012 Report Share Posted October 11, 2012 There is a 521 radiator in the bed of the 521 at the Sherwood Oregon Pick-n-Pull. Or at least it was there on October 10, 2012. 1 Quote Link to comment
Eagle_Adam Posted October 11, 2012 Report Share Posted October 11, 2012 if you want i can run up to that 521 if your willing to pay the $60 for the rad, $20 in gas, and shipping 1 Quote Link to comment
mrbigtanker Posted October 11, 2012 Report Share Posted October 11, 2012 After doing a reverse flush, the radiator still overheats so I took it into a radiator shop. They said the core is bad, and since the radiator isn't stock and it can be re-built for $300. Would a 510 or 620 radiator bolt right in? I heard I could use a Pontiac Fiero radiator but it would require adapters and hoses. Thank you for your help! Datsun parts unlimited Al Allen sells for like the same price.There aluminum and 3 core and work really good.he is also on ebay as well. Quote Link to comment
Eagle_Adam Posted October 11, 2012 Report Share Posted October 11, 2012 http://www.ebay.com/itm/NEW-ALUMINUM-3-ROW-RADIATOR-1968-1973-DATSUN-NISSAN-510-521-CC487-/160873439844?pt=Motors_Car_Truck_Parts_Accessories&hash=item2574cde264&vxp=mtr Quote Link to comment
Eagle_Adam Posted October 11, 2012 Report Share Posted October 11, 2012 damint - mrbigtanker beat me - ebay has some Quote Link to comment
Laecaon Posted October 11, 2012 Report Share Posted October 11, 2012 510 and 521 radiators are the same. Except the bolting on situation. Anyways I have put a 510 radiator on a 521, fit perfectly. Quote Link to comment
AcesHigh Posted October 11, 2012 Author Report Share Posted October 11, 2012 Would it be best to get a new radiator then? Quote Link to comment
Eagle_Adam Posted October 11, 2012 Report Share Posted October 11, 2012 $300 for a recore $ 230 for a new aluminum $120 ish for a used one delivered Quote Link to comment
AcesHigh Posted October 11, 2012 Author Report Share Posted October 11, 2012 230 is really good for a new radiator. I'm going to get the aluminum one on ebay. Thank you Eagle Adam for your help! Quote Link to comment
alabama_lowlife Posted October 11, 2012 Report Share Posted October 11, 2012 I bought one of the aluminum radiators off eBay to put in mine just a few months ago. I had to do a little tweaking and trimming to get it in just right. The top tank was touching the core support at the corners of the radiator. I took some vice grips and folded under the part of the core support that was touching. The bottom tank was touching as well so I had to trim a small amount of the core support with a grinder and a cutoff wheel. I had to cut the bottom center of the fan shroud off to keep the fan from hitting it because of the added thickness of the radiator. Probably an hour or less of fitting to get it right. Quote Link to comment
