rayven14 Posted October 9, 2012 Report Share Posted October 9, 2012 Well since I spent all this time and money on everything else I figured Id spend a little time trying to quiet things down a bit, since we all know Datsun are quite the "Tinny Lil Beast" when it comes to interior noise. So if you dont have one go get one of these and lots of these, in varied sizes. And if you decide to do your panels the way I did mine (most of you wont as I'vd discovered that most of the datsun guys are purist) and thats fine... but, you might need some of this anyway. Okay, so now go get some new 8th inch fiber board from your local big box store, like this Then locate and drill out the holes in the panels so they line up with the new holes in the panels, Nope, its not easy. In fact its a pain in the a$$ but once you figure it out ... your golden and it looks like this Okay, so because I wanted to do something different I added this piece, you'll understand why later in the thread I set it where I thoguth it looked good and drilled lots of little holes through the door panel and the inlay piece Then I removed it, cut wire about 12 inches long and looped them through the holes and upholtered the piece to match the rest of the interior The end result is this Ok, now back to the actual door panel. I outlined the inlay piece and surrounded the rest of the panel in foam, recycled foam none the less, so these panels are ECO friendly. Finish gluing the foam to the panel (but do not glue the 2 inches around the perimeter of the panel) and test fit the inlay, you should have about an 16th to an 8th of an inch of play. Okay, now take the inlay out and get your imported italian leather ready to go down, or in this case some sweet leatherette from your local fabric store and loosly (kind of) tack it in place. Now, remember those holes that were in the panel. Stick a small screw driver through those holes in that fine italian leather so you kno where they are and fish the wire from the inlay through those holes What you end up with is this At this point you wanna make sure your inlay is down nice and tight so lift the edges of the black leather and make sure the edges of the inlay are under the thick foam and the start to twist and secure the wire on the back side of the panel (not to tight or you'll tear the panel or break the wire) Now you want to drop in your new pins under the foam, remember you didnt glue the edges so this step is pretty easy. then start to stretch and attach the leather starting in the corners (at least that method works for me) and start gluing and stapling and trimming the excess material. What I ended up with was this Now I have to do the rear doors and the hatch. 5 Quote Link to comment
rayven14 Posted October 9, 2012 Author Report Share Posted October 9, 2012 But of course I didnt stop there! I went on to make a custom door pull, since my originals were shot the hell and back. TA-DAAAAAA 4 Quote Link to comment
rayven14 Posted October 9, 2012 Author Report Share Posted October 9, 2012 Cant decide if I like the handle/arm rest with or without the door pull. Although I do kinda need it to close the door. Quote Link to comment
rayven14 Posted October 9, 2012 Author Report Share Posted October 9, 2012 Seat belts came in today, When I first got em I was kinda like :confused: but after installing them I was like :w00t: they work great, I think. Well they look better than the factory units thats for sure. Now I can look over my shoulder and no have the seat belt across my face. 1 Quote Link to comment
INDY510 Posted October 9, 2012 Report Share Posted October 9, 2012 Epic .. . that looks great!!! .. :cool: .. .. damn that's alot of work Quote Link to comment
Draker Posted October 9, 2012 Report Share Posted October 9, 2012 Holy shit... very nice man!! Quote Link to comment
rayven14 Posted October 9, 2012 Author Report Share Posted October 9, 2012 Im sure most of the people in the San Jose Datsun community have seen this alredy but here is the custom dash build. It started with alot of wood and bondo. I'll spare you the whole build thread and show the OIC highlights The start I had two designs mocked up but liked one more than the other. One design was set up for gauges to go all the way across and the other was a little more realistic Test fit, blocked, primed, blocked and primed and blocked and primed Made a mold, made a part, cut some holes and off to the upholstery shop. (this is the mold, the plug and the part And the finished product, with Datsun Daves Push Buttom start :thumbup: 4 Quote Link to comment
Turbojovi Posted October 10, 2012 Report Share Posted October 10, 2012 what kind of self belts did you use? Quote Link to comment
Dawa Posted October 10, 2012 Report Share Posted October 10, 2012 holy guacamole!!! Quote Link to comment
rayven14 Posted October 10, 2012 Author Report Share Posted October 10, 2012 what kind of self belts did you use? Seat belts are from "Seatbelt Planet .com" Quote Link to comment
GUS-GUS Posted October 10, 2012 Report Share Posted October 10, 2012 Very nice!! I was pondering how you did all this last time I saw it at the santa clara meet. I hope you make it out to the swapmeet this saturday so I can take a closer look. Good job!! :thumbup: Oh and I may ask some advice on what material to use on the door panels for my little brothers wagon. :) Quote Link to comment
Green Queen Posted October 10, 2012 Report Share Posted October 10, 2012 looks great! Quote Link to comment
Eagle_Adam Posted October 10, 2012 Report Share Posted October 10, 2012 damn! stunning man! ive done my fair share of wood work, and i find it harder than wrenching as far as details. Good work Quote Link to comment
Just Joel Posted October 11, 2012 Report Share Posted October 11, 2012 Seat belts are from "Seatbelt Planet .com" Part number please... I need these before I kill a passenger (they never readjust the factory belt) Thanks Joel Quote Link to comment
rayven14 Posted October 11, 2012 Author Report Share Posted October 11, 2012 Joel, just go to their website, make a few measurements from the inside of the car and place yoru order. I dont recall seeing any part numbers. Quote Link to comment
blackwolf Posted October 13, 2012 Report Share Posted October 13, 2012 where did u get the pins for the door panel?? Quote Link to comment
rayven14 Posted October 14, 2012 Author Report Share Posted October 14, 2012 The pins came from "The fastener Wharehouse.com" Len is the guy you wanna talk to. The part number is TR308B, I paid 25 bucks for 200 pieces so they're very affordable. The seat belts were the 110 length with the 8 inch drop belt and the 8 or 12 inch buckle. 3 Quote Link to comment
DAT510 Posted October 14, 2012 Report Share Posted October 14, 2012 I saw your dime at the swap meet today! I didn't meet you, but my god what a beautiful interior you have! I was wondering if you had a build thread lol. Really, Great job! Quote Link to comment
cjzeppy Posted October 16, 2012 Report Share Posted October 16, 2012 This is pretty sweet, good work! Quote Link to comment
cxune Posted October 30, 2012 Report Share Posted October 30, 2012 Looks good- more photos! Quote Link to comment
