13 inches...
So i know that most 13" rims don't fit onto the 280zx front brakes. The only exception that I know of is diamond racing wheels and some others are easy to fit by either putting on a spacer or grinding down some of the caliper. Does anyone know it 13" SSR MKIII's or MKII's fit over the brake kit or will I need to grind the caliper.
Thanks for the help guys
  • Replies 3
You can fit the original 13x7 ARE Libres or 13x7 VTO Retro 4's over 280ZX brakes if you grind the ears on the mounting bracket . Just the bracket, the caliper doesn't need modification.
Here is the VTO Retro 4 installed on a 280ZX strut (longer studs are required for proper fit)..
