wat Posted September 27, 2012 Report Share Posted September 27, 2012 Right now my 510 has an l18 with a 32/36 in it with the stock jet settings Main Venturi: 26/27 Aux Venturi: 3.5/3.5 Main Jet: 140/135 Em Tube: F50/F6 Air Corr Jet: 165/160 Idle Jet: 55/50 Pump Jet: 50 Needle Valve: 2.00 My car runs pretty rich with this basic setting. My plugs are pretty black. This is a tired motor and I need to step it back a bit. I have 130/125 mains and I want to know if I can just throw them in there or if I need to redo all the jets If I were to jet it leaner. Is it simply a matter of of buying every jet setting one or two steps back? or could I replace the mains and be fine? Quote Link to comment
banzai510(hainz) Posted September 27, 2012 Report Share Posted September 27, 2012 be honest its already close to a l16 setting. whats you oil usage?????? fuck it just drive it. Quote Link to comment
wat Posted September 27, 2012 Author Report Share Posted September 27, 2012 It's not burning any oil. it's tired about about 10psi below specs but everything is 1/2 lb between each cylinder so it's not leaking. Valves are adjusted to a T. It just smells of gas and I get about 18mpg on 95% freeway. Initial puff of smoke when I gun it but again. I'm not losing any oil. So I can only assume because it's rich. Thoughts? Quote Link to comment
banzai510(hainz) Posted September 27, 2012 Report Share Posted September 27, 2012 I giess you could step it down to the number you gave . smell of gas? You got your crankcase tube to the pvc valve? And the top valve cover to the aircleaner? Quote Link to comment
EricJB Posted September 30, 2012 Report Share Posted September 30, 2012 Too much fuel pressure? Webers dont like a lot of pressure. Maybe the pump is pushing fuel past the the needle and seat. Or possilby float level. Quote Link to comment
