xzile609 Posted September 24, 2012 Report Share Posted September 24, 2012 Done allot of searching unable to find a good setup for Inter cooler radiator combos for this swap. Everyone seems to do it different which makes it confusing. they will look nice in pictures but the setup butchers the car pretty bad. Right now the CXracing IC seems to be the easiest to get and install. just not sure about what radiator to use with it. any help/ideas would be great thank you. Quote Link to comment
80datson Posted September 24, 2012 Report Share Posted September 24, 2012 98 Jetta Rad. 2.0 non turbo. Quote Link to comment
DISLEXICDIME Posted September 24, 2012 Report Share Posted September 24, 2012 ron davis works well with that ic and it is only $250 I am going to switch my set up to the cx racing ic and ron davis rad i cant remember the partr number for the ron davis rad . i am sure some one will chime in with it Quote Link to comment
xzile609 Posted September 24, 2012 Author Report Share Posted September 24, 2012 Ah yes the ron davis 1A-22163 Quote Link to comment
BoostinBen Posted September 25, 2012 Report Share Posted September 25, 2012 All depends on the cooling capacity you need for the SR.. Is this going to be a stock motor or built? I have run a couple different aluminum radiators First one was a summit universal, It was a 2 row aluminum, fit nicely. The second I have since upgraded to is a Griffin 4 row .. a bit wider and requires me to move the intercooler out a bit and space my grille a quarter inch.. I have part numbers written down for both of them at home ill look them up and post pics of both installed. I have seen all sorts of radiator / intercooler setups mounted. the biggest limiting factor is the depth, too deep and you will be running into the pully on the water pump. Here is some good info from another thread of some radiators commonly used in SR swaps Ron Davis 1A-22163 Summit Racing $175 http://www.summitracing.com/parts/SUM-380645/ NEW ebay for 510 Griffin Radiator $180 http://www.summitracing.com/parts/GRI%2 ... toview=sku Jetta GLX VR6 rad (rock auto)$200 Porsche 944 Turbo - New- 375 (rockauto) Mckinney - $540 Datsport - $2195 TSR- 600ish Classic Radiators 189. Seems like a great warranty http://cgi.ebay.com/ebaymotors/3-ROW-Al ... 102wt_1202 Quote Link to comment
