Bigger brakes on my 620
dscottdatsun
  • Replies 11
Finally got to finish bleeding the new brakes and take it for a little brake in (pun intended). It felt quite a bit better. It still feels a little bit soft but, I will bleed them again tomorrow.
Question: Could the softness be from the stock MC not be large enough for the double piston caliper?
This is the first third of my brake upgrade. Next up are the 15/16 MC and rear discs. Just need a bracket to mount the rear caliper. I just sent a pm to beebani hoping he is still selling it.
  • 2 months later...
other mods necessary?
Yea. It requires a balljoint front suspension, and hardbody spindles swapped in. I used the stock hubs and bolted the hardbody rotors to them.
Rims clear the calipers?
If when bled the peddle travel is too much you may need to go to a 15/16 zx master. Maybe, not sayin'.
They sure look nice!!
The stock rims fit same as before.
Tryin' to get the other projects out  of the shop so I can get the rest of the swap/upgrade done.
Thanks, they work well too.
