D52E Posted September 21, 2012 Report Posted September 21, 2012 Not sure if this is the best way to do this but this is the way I chose to do it. As most of you may know, the ignition switches on our Datsuns are over 40 years old and many of them turn with just about any key. I chose to disassemble mine to re-key it along with some door locks. The goal is to make all the locks work with one key. My first acquisition was a Datsun/Subaru re-key kit from eBay: I started by removing the ignition switch assembly and removing the face cap: I then lifted the black plastic ring that holds the steering column lock lever inside the assembly. This was required in order to remove the black electrical switch on the side. The next step was to remove the metal pin that secures the lock cylinder portion. I chose to drill a hole in the lock cylinder to access the pin from the back side and push it out. This was possible after removing the black plastic switch on the side. After removing the pin holding it together I pulled it apart and removed the steering lock lever with black plastic ring. A word of caution, there is a small spring that comes out with the lock cylinder. Make sure you don't lose it. The key cylinder and tumblers are held together by a little brass wafer that can be pushed in to let the key cylinder slide out. After you slide the key cylinder out you can get to the tumblers. These are little brass inserts that are coded 1 to 4 depending on the key code. You change these out until you get the correct combination that results in flush tumblers with the key inserted. Without key: Key inserted: Here is a sample of one of the tumblers coming out 1 Quote
thumper Posted September 25, 2012 Report Posted September 25, 2012 Awesome. I was thinking about doing this just a few days ago. Time to look for a kit on ebay. Thanks Quote
D52E Posted September 28, 2012 Author Report Posted September 28, 2012 Next was the key cylinders. I started with a sample piece to avoid ruining one of my 510 pieces. First step was to remove the bracket on the back side of the key cylinder - it's held in with a c-clip. Second - gently pry the back side of the face cap lip. and then remove the face cap: Remove the internal key cylinder and change tumbles as done previously for ignition switch: Reassembly is done in reverse. A word of caution - be gentle with the face cap installation. Take your time rolling the lip back over the outer edge. Quote
oakespreformance Posted January 9, 2013 Report Posted January 9, 2013 would it be the same for a 240z's switch looks about the same Quote
ggzilla Posted January 9, 2013 Report Posted January 9, 2013 Did you fit a new key? Because usually only the key is worn. You can either get a code-cut key (which will match the doors), or buy a new key and rekey the lock. A code-cut key is about $40. Quote
D52E Posted January 9, 2013 Author Report Posted January 9, 2013 (edited) oakesperformance - I'm not sure if a 240Z is exactly the same but the ignition switch assembly in the pictures was taken from a 1978 280Z at the junkyard. My 1970 510 originally had the single side cut keys and I wanted to put together a double side cut key set together. ggzilla - I did happen to purchase a new ignition lock key cylinder after the first attempt. it worked out better since it came with a new cut key that I used to re-key all my locks. Its great having one key that fits every lock. Before I had 4 different keys (ignition, doors, trunk, fuel). Note - If you are at the junkyard looking for an ignition switch donor vehicle (240Z 260Z 280Z 510) be sure to measure the steering column diameter where the switch bolts on. The first one i purchased was not the correct size for my 510. Edited January 9, 2013 by D52E Quote
oakespreformance Posted January 10, 2013 Report Posted January 10, 2013 if it came off a 280 they are the same i believe Quote
oakespreformance Posted January 10, 2013 Report Posted January 10, 2013 how did you get the tumblers out Quote
D52E Posted January 10, 2013 Author Report Posted January 10, 2013 I just used a tool similar to a dentist pick to pry them out. On the tumblers/wafferson there is going to be a little bit of resistance from the little tangs that press on the springs but they do pull out Here is a sample of one of the tumblers coming out Quote
oakespreformance Posted January 10, 2013 Report Posted January 10, 2013 thanks helped a bunch that is the sama as a 240z switch Quote
dakotahchore Posted May 29, 2013 Report Posted May 29, 2013 Find myself hunting for one of those rekeying sets... any sources? Quote
Camtron Posted June 4, 2013 Report Posted June 4, 2013 http://d1086208-345.site.myhosting.com/auta16100-01-1575.html Kinda spendy, but this is all I've found. I've had an alert for this kit set up on eBay since I read this how-to and still haven't seen one come up. Might hafta bite the bullet and pay. I've thought about offering rekeying services to try to offset the price, but it would be tough to do by mail. People would be lockless for several days. A dude could make a killing at Canby or other Datsun shows/meet-ups. One of you west coasters oughta think about it :thumbup: Quote
dakotahchore Posted June 4, 2013 Report Posted June 4, 2013 http://orders.stoneandberg.com/advancedwebpage.aspx?cg=189&cd=4&WebID=2306&SKU=2306&SKUFLD=SKU&SKUTYPE=202 How's this look? Same model number as the one in original post. Quote
HKS Posted November 4, 2013 Report Posted November 4, 2013 Looked high and low for a company that sells the ASP A16-100 to the general public. looks like you can buy from the majority of these sites only if your a certified locksmith. Anyone else have any luck? Quote
