SHORTDOG Posted September 20, 2012 Report Share Posted September 20, 2012 Does any body know of an easy way to clean out the air vents from being clogged with leaves on a 720?? Is there a way to take them out with out puling the dash?? :confused: Quote Link to comment
datzenmike Posted September 20, 2012 Report Share Posted September 20, 2012 Remove wipers, unscrew the cowl and remove it. This will give access to the wiper linkage area where the leaves settle. In the cab, direct compressed air into the vent. This should blow the debris back into the plenum where you can vacuum it out. Quote Link to comment
c10jim Posted September 20, 2012 Report Share Posted September 20, 2012 Se habla "matches"? Go with Datzenmikes solution. Quote Link to comment
