kelowg Posted September 14, 2012 Report Share Posted September 14, 2012 What is the ring gap suppost to be. Inch or mm. Manual says .009 to .0156 or something like that Quote Link to comment
datsunaholic Posted September 14, 2012 Report Share Posted September 14, 2012 Inch. You'll never find a .009mm feeler blade... .009 mm is 1/8th the thickness of a sheet of 16# paper. Quote Link to comment
kelowg Posted September 14, 2012 Author Report Share Posted September 14, 2012 So what do u guys set them too? Quote Link to comment
Jayden71 Posted September 14, 2012 Report Share Posted September 14, 2012 .009inches?? Quote Link to comment
datsunaholic Posted September 15, 2012 Report Share Posted September 15, 2012 .015. I like them not dead on minimum. .009 is too close for a L20B. Factory manual for an L20B top ring is .0098-.0157. That's .010-.016 on feeler blades. 2nd ring is .0118 to .0197, whoch is .011 to .020 on feeler blades. Oil rings are .011-.035, BIG range there. But I set everything to .015. .015 blade goes in, .016 doesn't. Quote Link to comment
I'm BLUE Posted September 15, 2012 Report Share Posted September 15, 2012 Also as a side note.. Make sure when you're compressing your rings The oil-ring's don't jump the gap ! ( as in over-lap ) "Grant" brand rings purposely color one end of the control ring *Green* and the other ring end *Red* as a teller for this very purpose. If it jumps .. likely that cylinder will eat oil like it's going out of style. Quote Link to comment
kelowg Posted September 15, 2012 Author Report Share Posted September 15, 2012 Black ring and bore facing edge painted/coated silverish white. Marked on one side with a N. What the hell is that all about? Quote Link to comment
kelowg Posted September 15, 2012 Author Report Share Posted September 15, 2012 Coated ring is a hair smaller uncompressed Quote Link to comment
I'm BLUE Posted September 15, 2012 Report Share Posted September 15, 2012 Black ring and bore facing edge painted/coated silverish white. Marked on one side with a N. What the hell is that all about? Depending on the piston ring itself.. probably indicator of piston ring direction = "This side up/This side down" grab the instruction's the piston ring's came with to verify :) It takes me a while to check ring-gap then lightly grind down piston ring edges ( if gap is too tight ) then check again carefully ... and be satisfied at the same time lol. quality piston-ring grinder is worth it's weight in gold is all I have to say. Some old timers just use files ( I can't keep it straight enough when I've tried ). 1 Quote Link to comment
kelowg Posted September 15, 2012 Author Report Share Posted September 15, 2012 No paperwork with them damn it Quote Link to comment
I'm BLUE Posted September 15, 2012 Report Share Posted September 15, 2012 errrrrr that sucks. I would advise stopping until you're 100% sure and seeing if you can research or look on a website/call someone. my "assumption" is that if no other markings on the rings themselves ... then N = "up" But again I am assuming and assuming without fact is best to avoid when possible . Some rings are literally marked "TOP" or "T" or ... how the manufacturer see's fit to mark the direction :unsure: Hopefully the if you have some still in the package , and they haven't been touched take a quick look to see which way is up ( specifically the "N" marking ) ( piston rings should be in order per set and direction .. I think !? ) Quote Link to comment
datzenmike Posted September 15, 2012 Report Share Posted September 15, 2012 Top ring.... 0.0045" for every inch of bore. 86mm = 3.388 X 0.0045 = 0.015" This is about right for what Doug likes 2nd ring.... 0.0055" for every inch of bore. 86mm = 3.388 X 0.0055 = 0.018" Quote Link to comment
datsunaholic Posted September 15, 2012 Report Share Posted September 15, 2012 Oh, and don't file ANY rings until you've tried them in the cylinders. You might find one fits one cylinder better than the others. Quote Link to comment
