Green Bastard Posted June 1, 2008 Report Share Posted June 1, 2008 Mods, sorry for starting another Canby thread, but I wanted people to see this. This is a great opportunity to test and tune your car. Cox Performance Motorsports is bringing a dyno to the show for both days! For those who dont know, a dyno is a tool to measure the horsepower and torque at your drive wheels. You strap your car to it, and do a full throttle run, usually in 3rd gear. Horsepower and torque is measured and plotted out across the RPM range. Pretty safe and fun stuff. Special show prices are: * 2 runs for $40 * 1 drag run for $35 or * 2 runs and 1 drag run for $50 All runs come with certificates of HP and Torque and times Got a friend with BS stories about how fast his car is? 200? 300 hp? 12 second quarters? whatever, here is your chance to make him prove it! :D Quote Link to comment
Bleach Posted June 1, 2008 Report Share Posted June 1, 2008 Sounds nice. I've always heard that your 1:1 ratio gear is the one you use on a Dyno. Quote Link to comment
808DA6 Posted June 2, 2008 Report Share Posted June 2, 2008 Saaaaaweeeet! I have been officially convinced to take Sat and Sun off from work to be there. -Brian Quote Link to comment
Green Bastard Posted June 2, 2008 Author Report Share Posted June 2, 2008 I've always heard that your 1:1 ratio gear is the one you use on a Dyno. I have done HP/Torque pulls on two different dynojets, third gear was used both times. If you wanted a top speed reading, 4th could be used. You could even do all the gears, if you wanted to know different speeds through the gears, although math would work just fine for that also. From what I could tell, if you want to map your power throughout the RPM range, you basically want a gear that will give a long slow pull from as low of an RPM as possible. 1st or 2nd will be too spikey, and with a taller gear like 4th or 5th, you may not be able to get the rollers going at a low enough RPM. Now for just a max power or dragstrip pull, things may be different. Also, there are different models of dynos too. I guess we will see how the Cox guys do theirs. Bleach, how long has your avatar been animated? I just noticed. :) Quote Link to comment
Bleach Posted June 2, 2008 Report Share Posted June 2, 2008 Its been animated for about 3 months now. Back in 99 when I dynoed my 280ZX they told me 4th gear only. I did 3 pulls. Recently I dynoed my 350Z and they did a couple 4th gear pulls (I thought for warmup, since 5th is the 1:1 ratio) and then one 5th gear pull. (its a 6-speed) 1:1 gear produced a more smooth curve and slightly more torque. Just wondering though. I'm not a dyno expert. My car is still stock though so I wont' be needing another pull. If I bring an electric car, we can do a 4th gear pull right from a dead stop! :D Quote Link to comment
mklotz70 Posted June 2, 2008 Report Share Posted June 2, 2008 We'll see how the NL is running......Be fun to get some pics of it on the dyno! See if it can live up to the 60hp badge on the fender :) Quote Link to comment
ggzilla Posted June 2, 2008 Report Share Posted June 2, 2008 See if it can live up to the 60hp badge on the fender 60 HP is at the flywheel, where manufacturers measure HP. The dyno will measure HP at the wheels, expect less than the flywheel rating. Newer cars with updated SAE specifications have a closer figure, about 1/3 down at the wheels...they say it is the drivetrain (gear mesh, transmission oil, etc) that takes the HP away. Expect a top E12 Datsun 320 engine to be around 30 HP at the wheels. Quote Link to comment
Icehouse Posted June 2, 2008 Report Share Posted June 2, 2008 When I dynoed my SR in my S13 they did it in 4th gear as well. My buddy had a B13 when he dynoed it they did it in 3rd.... seems weird to me. Quote Link to comment
mklotz70 Posted June 2, 2008 Report Share Posted June 2, 2008 I figured that after accounting for parasitic drivetrain loss, it would show if it's close or not. Besides.....I think it would be worth the $40 just to get some pics of it on the dyno! :) Quote Link to comment
Bleach Posted June 2, 2008 Report Share Posted June 2, 2008 of course. When I finish the fairlady with a stock L20 I'm going to dyno it. maybe 75whp? :) Quote Link to comment
Icehouse Posted June 3, 2008 Report Share Posted June 3, 2008 60 HP is at the flywheel, where manufacturers measure HP. The dyno will measure HP at the wheels, expect less than the flywheel rating. Newer cars with updated SAE specifications have a closer figure, about 1/3 down at the wheels...they say it is the drivetrain (gear mesh, transmission oil, etc) that takes the HP away. Expect a top E12 Datsun 320 engine to be around 30 HP at the wheels. The Canadian datto dude's dynoed a 100% stock 510 and found that at worste the 510 drive train loss is about 17% not to bad I though. Now if you add a ford 9" and some other hard to turn bits I can see added loss. Quote Link to comment
ggzilla Posted June 4, 2008 Report Share Posted June 4, 2008 Sure, 17% of net, e.g. 1973 510 ratings. But 1968 ratings were not SAE net, they were GROSS which were higher, less accurate ratings. So expect a big difference at the rear wheels. Somewhere between late 60s and early 70s the measurements change from GROSS to NET. For american manufacturers as I recall it was 1971. Quote Link to comment
ariascarlos1990 Posted June 15, 2008 Report Share Posted June 15, 2008 i didn't see the dyno there today. where was it at? Quote Link to comment
