scarea510 Posted September 10, 2012 Report Share Posted September 10, 2012 So I was able to pick up an sr20 for a good price and figured now would be the best time to install the late 5lug 200sx struts I am getting from a friend for better braking , my main worry is not to long ago I went spend crazy and bought pretty much everything t3 makes besides their coilovers(lcas, tc rods, outer tie rods, and rcas) and was wondering if all these can still be used with the 200sx struts or not . Luckily I talked to t3 and they said they would do an exchange since none of the parts have even been mounted, thanks in advance for the help Quote Link to comment
datzenmike Posted September 10, 2012 Report Share Posted September 10, 2012 None of the suspension parts listed bolt to the strut itself. As long as you keep and use the 510 LCA it should work ok. If just wanting a brake upgrade the zx and Maxima struts have large calipers, vented rotors and they are 4 bolt to match the rears. You are still going to need a larger master cylinder if going to larger calipers no mater which you choose. Quote Link to comment
Skib Posted September 10, 2012 Report Share Posted September 10, 2012 (lcas, tc rods, outer tie rods, and rcas) none of that stuff bolts to the strut tube. when you just swap strut tubes to 200sx or 280zx ect your not changing anything but the strut tube. Quote Link to comment
thisismatt Posted September 10, 2012 Report Share Posted September 10, 2012 The only "problem" you'll run into (and this is also true for the 4lug s12 200sx struts) is that the cup at the bottom of the strut which interfaces with the steering knuckle is a larger diameter than the boss on the steering knuckle. The bolt size & spacing is correct, though. The cup and boss are meant to be a tight fit so that the two bolts connecting the steering knuckle to strut are not the only attachment points in single sheer. You can turn a spacer to take up the slack, or find someone to make RCA (roll center adjusters AKA bump steer spacers) that go from the 510/280zx size steering knuckle boss to the 200sx size strut tube cup. Mattndew76 has made some of these in the past (I have a set) and you could try pm'ing him to see if he has any left or plans to do any more. Quote Link to comment
510T Posted September 10, 2012 Report Share Posted September 10, 2012 All you will need to use those strut tubes (s12 V6) is a special spacer. Made by Mattndew76 here and datsunwizard here maybe some other people make them too? T3? Edit: too slow haha Edit 2: If you decide against it I will buy those struts and hubs. Quote Link to comment
scarea510 Posted September 11, 2012 Author Report Share Posted September 11, 2012 Yeah I just realized about the lcas AMD what not from looking under my car(been working on 240sx lately and got all confused) but thanks for the information on the rcas , and I'm gonna keep the struts cuz I plan on adapting s13 coilovers to them out of a set of powered by max coilovers I got for free Quote Link to comment
datsunwizard Posted September 11, 2012 Report Share Posted September 11, 2012 I have one set of 1" 200sx v6 roll center adjusters AKA bump steer spacers left from the last run. These adapt the 510 steering arm to the 200sx v-6 struts. Let me know if you might be interested. Quote Link to comment
