onunez65falcon Posted September 7, 2012 Report Share Posted September 7, 2012 I just installed a master cylinder to my 520 truck, next will be the rear disc Brakes. Quote Link to comment
flatcat19 Posted September 7, 2012 Report Share Posted September 7, 2012 What booster is that? Keep track of all you progress with words and pics. It will be a good reference for all. What will you be using for your other brake parts. Keep up the work! :thumbup: Quote Link to comment
bigman420 Posted November 4, 2012 Report Share Posted November 4, 2012 Yes what booster Quote Link to comment
onunez65falcon Posted November 7, 2012 Author Report Share Posted November 7, 2012 It come out of a 1990 geo metro, I will be posting all the pictures and modification that it need to be done for this to work on the 520 I finish my front disc brake conversion already, I did my first driving test and they work great (Isuzu rodeo rear rotor, 91 Acura legend rear calipers and a custom bracket) Quote Link to comment
wayno Posted November 7, 2012 Report Share Posted November 7, 2012 This will not work in a 521 guys, the 520 brake master is several inches away from the clutch master, in the 521 they are right next to each other, and he also has a J block in his truck, while the L block is much higher and the intake gets in the way. This is how I did my 520 with an L block in it, this is a stock intake manifold, but I have a shorter "offenhauser" manifold I will be using down the road. This is very tight, this is what happened when I tried to use a traditional brake master, the bleeder screws hit the carb/intake. The 521 has to have a custom booster pedestal made, see how tight everything is. Quote Link to comment
XXL Posted January 27, 2013 Report Share Posted January 27, 2013 Wife just drove the new 520 around the block. She doesn't "get" old cars, and I'm surprised she even wanted to drive it at all (probably first and last time she will... she hates "car stuff" and hasn't ridden my my other project vehicle in 10+ years). Her first comment was that it needs new brakes. Actually, the brakes on it are new... and working as designed. However, I do like the idea of maybe putting a little boost on them like you're doing in this thread. So... subscribing and following your progress. Quote Link to comment
XXL Posted January 27, 2013 Report Share Posted January 27, 2013 This will not work in a 521 guys, the 520 brake master is several inches away from the clutch master, in the 521 they are right next to each other, and he also has a J block in his truck, while the L block is much higher and the intake gets in the way. BTW, in my other truck (see last pic in my intro post http://community.ratsun.net/topic/51431-new-520-owner/ ), I built a right angle assembly and stuffed the booster and MC under the dash. Has anyone looked at doing the booster/MC under the dash on the Datsun? I have radio delete on my truck and with a tiny low power flashlight I peeked under there and my first impression is that a 7" dual diaphragm might actually fit, and then just do a right angle Heim joint to actuate. (???) Quote Link to comment
XXL Posted January 27, 2013 Report Share Posted January 27, 2013 Has anyone looked at doing the booster/MC under the dash on the Datsun? I have radio delete on my truck and with a tiny low power flashlight I peeked under there and my first impression is that a 7" dual diaphragm might actually fit, and then just do a right angle Heim joint to actuate. (???) Well, that was a dumb idea. There's a giant heater in the way. Quote Link to comment
520 gasser Posted January 27, 2013 Report Share Posted January 27, 2013 Could you mount the clutch master cylinder under the dash at a right angle is there space between the pedal assembly and the kick panel. That would allow the booster to be mounted closer to the fire wall Quote Link to comment
