mrbigtanker 11,351 Posted July 21, 2016 Report Share Posted July 21, 2016 Do you still have the fj20 510 mounts? I dont know, actually I think Joe up north got them. 1 Quote Link to post
Draker 15,307 Posted July 24, 2016 Report Share Posted July 24, 2016 What do we know? 3 Quote Link to post
S30Jay 421 Posted July 24, 2016 Report Share Posted July 24, 2016 I was wondering that also. 2 Quote Link to post
The Engine Room 156 Posted July 24, 2016 Report Share Posted July 24, 2016 So is that 60 good or bad.looks like the point when a big trucks air brakes go in to low alarm. Not good I would say. Let me know I got a FJ20 for sale. The compression test shows how much each cylinder is compressing the fuel/air before it is lit by the spark plug. The little numbers inside the gage roughly correspond to the actual compression ratio -1 so cylinder 1 is building around 9.75:1 compression. The other 3 are less than 6:1 so 1/2 of the fuel/air mixture is leaking out of the cylinder (probably past a broken ring) and making half as much power as cylinder 1. 2 Quote Link to post
510T 1,790 Posted July 24, 2016 Author Report Share Posted July 24, 2016 All we know is that we are glad to have gotten it out of the car on Friday. Yesterday I was re-purposed as a ceiling fan installer and dump run guy. The fan works great and the yard looks nice again but the SR20 is still untouched. Today after the grocery store and an errand or two I hope to get the clutch and flywheel off then put it on the stand. The Engine Room thanks for spelling it out for Tanker! I think he was just being cute though... FJ20's are pretty neat but I can't imagine parts are easy to get. 2 Quote Link to post
The Engine Room 156 Posted July 25, 2016 Report Share Posted July 25, 2016 The Engine Room thanks for spelling it out for Tanker! I think he was just being cute though... I learn the most when I ask questions I think I know the answers to and play dumb. 2 Quote Link to post
510T 1,790 Posted August 4, 2016 Author Report Share Posted August 4, 2016 Today I got the block apart. #2 was the worst but 3 and 4 were bad too. Still not sure what I'm going to do... 2 Quote Link to post
Draker 15,307 Posted August 4, 2016 Report Share Posted August 4, 2016 How are the walls? 2 Quote Link to post
510T 1,790 Posted August 4, 2016 Author Report Share Posted August 4, 2016 Not great. Scored from the broken rings and piston skirt and pitted from detonation. 1 Quote Link to post
Draker 15,307 Posted August 4, 2016 Report Share Posted August 4, 2016 Might be cheaper to find a jdm long block? I have no idea.. just tossing out ideas. Jdm forced induction can be a shot show also.. I'm staying tuned.. gl! 2 Quote Link to post
Laecaon 1,434 Posted August 4, 2016 Report Share Posted August 4, 2016 Probably a good time for forged internals too. Maybe a bore job will work for you. I went with CP Carillo pistons for my CA. Everyone says they are noisy on cold starts, but stand up way better than anything else to a bad tune (like driving 50 miles home pinging the hole time); this is due to the alloy 2618, which many other companies use. Also, they seem to have one of the tightest tolerance for weight matching of Piston makers, mine were +/- 0.8g. 2 Quote Link to post
DISLEXICDIME 489 Posted August 4, 2016 Report Share Posted August 4, 2016 Oh man you messed with the danger zone and got burned. I take it you didn't have a wide band ? Hopefully you can get a way with boring the sleeves to the next size up you can make it a 2.2 . Then get injectors and a tune 2 Quote Link to post
The Engine Room 156 Posted August 5, 2016 Report Share Posted August 5, 2016 If he outran the stock fuel system then the damage is from going hot lean; and the broke rings are the RESULT of other damage to the cylinder walls. I'd say that the block is shot. 2 Quote Link to post
Lozer 152 Posted August 5, 2016 Report Share Posted August 5, 2016 Do Not Like..... I have a spare ka block you can have, needs a busted bolt removed and a good .20 cut before use. Also have a spare kade crank and single cam head. 2 Quote Link to post
soundboi 28 Posted August 5, 2016 Report Share Posted August 5, 2016 swap in a s15 motor 2 Quote Link to post
S30Jay 421 Posted August 5, 2016 Report Share Posted August 5, 2016 On the bright side the pistons would make nice garage art! Sorry it's such a mess, that engine seems like it was a good runner. I'm sure replace it with a winner though! 2 Quote Link to post
510T 1,790 Posted August 14, 2016 Author Report Share Posted August 14, 2016 Scored a new engine. The 300k fit sure comes in handy! Eagle rods, Supertech 9:1 pistons, clevite bearings, bc valve springs and retainers. New valves new timing kit ARP bolts Greddy pan blah blah blah. Also got a fancy fuel rail and some big injectors. I need to order a few odds and ends but should be back up and running in less than a month. :frantics: 7 Quote Link to post
Draker 15,307 Posted August 14, 2016 Report Share Posted August 14, 2016 Ok now you are allowed to turn up the boost. :) 4 Quote Link to post
510T 1,790 Posted September 19, 2016 Author Report Share Posted September 19, 2016 Yesterday the new SR was finally dropped in. I have been messing around with it for the last few weeks trying to get everything ready. I had a small hiccup when removing the rocker arm stoppers that the PO had installed. I bought a cheap HF inch-pound torque wrench and the first time I used it I broke 2 cam cap bolts and almost a third. I was successful removing the first by supergluing the bolt back together and twisting it right out. The second I had to drill and extract which actually worked but I sure was nervous doing it. I had some parts lying around and had ordered a bunch more. New dipstick and tube had to be custom bent and the addition of a turbo blanket caused quite a bit of work. Getting the oil feed tight proved to be quite a challenge. Stripped valve cover B) I was lucky to have a pro come over and keep me on track. Rag10 (Tim) was super helpful and shared all kinds of tricks that really made the install smooth. We got the flywheel and clutch on then re-torqued the crank pulley and dropped it in. :w00t: The next couple afternoons I need to install the starter then intake, get the radiator back in then hook up all the plumbing and wiring and it should be good! Track day is Saturday!!! 8 Quote Link to post
S30Jay 421 Posted September 22, 2016 Report Share Posted September 22, 2016 I'm excited for you! I can't wait to see videos of this old girl tearing up the track again! 3 Quote Link to post
Charlie69 5,974 Posted September 22, 2016 Report Share Posted September 22, 2016 Nice progrees! Keep at it and we need videos from Sunday track day. 1 Quote Link to post
Draker 15,307 Posted September 22, 2016 Report Share Posted September 22, 2016 Yessss!!! 1 Quote Link to post
510T 1,790 Posted September 23, 2016 Author Report Share Posted September 23, 2016 First start: :crying: Quote Link to post
shacks510 1,213 Posted September 23, 2016 Report Share Posted September 23, 2016 uggggggghhhhhhhh nooooooooo 2 Quote Link to post
