wat Posted August 21, 2012 Report Share Posted August 21, 2012 my l18 is starting to get tired. I'm sure she has a lot of life in her left but I don't want to be caught off guard when she decides to finally shuffle off her mortal coil. So I'm looking for a z22 block to slowly start building. Looking for cheap. Doesn't even have to be pretty. As long as it's salvageable. It should be a complete block though. I don't want to have to search for caps and bolts. Post offers. Link to comment
datzenmike Posted August 21, 2012 Report Share Posted August 21, 2012 Keep on the lookout for an L20B for the parts to make an LZ22 Link to comment
wat Posted August 21, 2012 Author Report Share Posted August 21, 2012 I will be doing that too, but one step (and paycheck) at a time. Link to comment
datzenmike Posted August 21, 2012 Report Share Posted August 21, 2012 Just keep eyes open all the time. You'll need all the L timing stuff from the block/crank forward, L motor mounts, oil pan and the manifolds and an L head. All this stuff can be found on a non running motor. Link to comment
datsun510 Posted August 21, 2012 Report Share Posted August 21, 2012 Also need the 6 bolt flywheel to install. Link to comment
wat Posted August 21, 2012 Author Report Share Posted August 21, 2012 Good to know. Also i noticed this is in the wrong section. Whoops Link to comment
The Dat-side Posted August 21, 2012 Report Share Posted August 21, 2012 You're in Vancouver? This isn't mine, and it's not that bad of a drive down to Newberg. Prob 30-45 minutes. http://portland.craigslist.org/yam/pts/3218906853.html Link to comment
datzenmike Posted August 21, 2012 Report Share Posted August 21, 2012 The Z22 are 6 bolt also and because they were used in car and trucks come in 200mm and 225mm size pressure plate.. Link to comment
datzenmike Posted August 21, 2012 Report Share Posted August 21, 2012 You're in Vancouver? This isn't mine, and it's not that bad of a drive down to Newberg. Prob 30-45 minutes. http://portland.crai...3218906853.html That's either a Z20E or a Z22E motor used in the S110 200sx. Phone and find out.m Link to comment
Guest kamakazi620 Posted August 21, 2012 Report Share Posted August 21, 2012 That's either a Z20E or a Z22E motor used in the S110 200sx. Phone and find out.m Most likely a Z20 from the vavle cover............ Link to comment
datzenmike Posted August 21, 2012 Report Share Posted August 21, 2012 The Z24 had the different taller stamped steel valve cover. The Z20 and 22 had the cast ones that I like with longer bolts. Looks like a 348/409 valve cover eh? You're back!!!! Link to comment
wat Posted August 27, 2012 Author Report Share Posted August 27, 2012 WTB z22 for an LZ conversion. So I am not so much worried about the head as I am the bottom end. Post offers. Link to comment
