Turboragtop Posted August 21, 2014 Report Share Posted August 21, 2014 Don't want to say anyone is wrong on ring gap orientation, but piston rings DO ROTATE in operation. 2-cycle engines actually have 'stop pegs' in the ring gaps, specifically to prevent ring rotation. 2-cycle engines can break the rings on port edges if allowed to float around. Here's an eye-opener. http://www.diagnosticengineers.org/journal_%20articles/Ring%20Gaps%20vs%20Knowledge%20Gaps.php Flame suit *ON* Quote Link to comment
datzenmike Posted August 22, 2014 Report Share Posted August 22, 2014 Interesting. I will still stagger the rings and properly end gap them when installing, even it they might migrate later. 1 Quote Link to comment
datsunaholic Posted August 22, 2014 Report Share Posted August 22, 2014 You don't want them lined up on initial install because if they DON'T rotate (and yes, I know they normally do) you end up with a weird wear pattern. Now, 3-piece oil rings, which are still used today, absolutely need to be staggered. They rotate as a unit, not independently. You don't want the gap of the expander lining up with the scrapers. It can make the expander "jump" and become useless. Quote Link to comment
Jeremiah720 Posted September 1, 2014 Report Share Posted September 1, 2014 I have actually used the plasti-gauge wrapper to fix a clearance on a bearing on my small block chevy. Just cut it to the size of the bearing and slipped it under the bearing. :angel: Quote Link to comment
datzenmike Posted September 1, 2014 Report Share Posted September 1, 2014 Paper or cardboard?????? While this will 'work' it's surely not a permanent fix. Brass shims were used in the 'old days' to correct bearing clearance but never recommended in today 's close tolerance higher power engines. Chevy owners.... (shakes head in wonderment) 1 Quote Link to comment
rbastedo Posted September 25, 2014 Report Share Posted September 25, 2014 Thanks everyone, just read through the whole thing. Very good reminder of what to do / not do before I get my new rings. 1 Quote Link to comment
ryanthomas1 Posted January 4, 2015 Report Share Posted January 4, 2015 For the love of god and ratsun, please clock your rings appropriately to prevent heavy blow by. I do mine 180 degrees of eachother if no spec is given by the ring manufacturer. Also, a pair of ring pliers would be great , helpful for installing them without breaking them. Practice with the old rings to get used to handling them. While your in there replace bearings , there cheap and tighten up the clearances. 1 Quote Link to comment
datzenmike Posted January 4, 2015 Report Share Posted January 4, 2015 They also can't be facing along the length of the crankshaft or at 90 degrees to it. This leaves the top one at either of the four 45 degree angles and the second one 180 to that. 1 Quote Link to comment
84720FourWheel Posted January 14, 2015 Report Share Posted January 14, 2015 During lower engine class my instructor explained why older engines had to have the ridges reamed. They used to use high tension rings, which are generally made of cast iron. This wears the block faster, and since the rings don't go up to the top of the cylinder, it leaves a ridge of unworn metal. Most engines made after the mid eighties use low tension rings. You can compress th em fairly easily by hand. I forget what they are made of. I want to say CrMo. 1 Quote Link to comment
distributorguy Posted March 22, 2019 Report Share Posted March 22, 2019 Good modern rings use a stainless top ring, ultra-low tension, and about 1/4 the thickness of what you got in a Chev 327, Ford 289, or similar of the era. The 2nd ring is typically cast, oil control rings come in 2 varieties also ultra-low tension. With the quality of Datsun blocks, I'd be surprised if there was ever a ridge present with any amount of mileage, using any style pistons and rings. Its far more likely to see a gouge in the bore wall at the bottom of the stroke. Its not present until you give the cylinder walls a quick hone, and a dead spot appears on the passenger side of the bore from piston tip. 1 Quote Link to comment
datzenmike Posted March 22, 2019 Report Share Posted March 22, 2019 Info is good but the post is 4 years old. 84720fourwheel hasn't visited in 2 years. 1 Quote Link to comment
4perrev Posted June 15, 2019 Report Share Posted June 15, 2019 Man, you don't miss a thing! I write this as I look at your signature above. So fitting...."You're goddam right!!" 1 Quote Link to comment
