zenndog Posted August 22, 2012 Report Share Posted August 22, 2012 My L320 has a J13 in it. I think the air cleaner is the stock 320 air cleaner but I am not sure. Either way, there is a gap between the air filter housing and the top of the carb. When I got the truck there was a stock seeming plastic spacer ( widget ) which promptly fell apart after a couple of remove/replace cycles. I rigged it with some electrical tape. Move forward 4 years and after sitting for a year with a clogged non functioning carb, as part of repairing the carb, I decided to make a new widget and remove the tape forever. Here is the air filter housing and carb Here is my second sketch, the first was over thought and scrapped. Here is the chunk of aluminum on the chucker Here is the widget on the carb and bottom/top of the air filter housing I am happy to say that the truck started after a year in mothball, I can pretend that the widget made all the difference even though I know better! 1 Quote Link to comment
Tristin Posted August 22, 2012 Report Share Posted August 22, 2012 Sweet machine skills! Quote Link to comment
wayno Posted August 23, 2012 Report Share Posted August 23, 2012 Nice job, looks real good, a lot better than I would come up with. :thumbup: Quote Link to comment
zenndog Posted August 23, 2012 Author Report Share Posted August 23, 2012 I didn't check in the bed to find the tightening screw with the triangle tip that broke off. I think I tossed it in there a year ago and i plan to weld it to a new piece of 1/4-20 threaded rod to fix the screw. Should get it done by next year....... :blush: I will try to get a better pic also, I didn't show how i put two slits in the spacer so it will allow the filter housing to tighten on to the carb. Quote Link to comment
zenndog Posted August 24, 2012 Author Report Share Posted August 24, 2012 A couple people asked, this is a link to the guy who rebuilt the carb http://www.yelp.com/biz/woodman-carburetor-and-fuel-injection-inc-arleta He charges around $190, I talked him down a little but I was there in person and had cash. It took one day. He is a bit of a character but I have used him before. Not sure how it would be to deal with him through the mail. He builds the kit from various other bits and won't sell it separate....I tried to buy a rebuild kit from him but had to cough up the dough. Quote Link to comment
Stoffregen Motorsports Posted August 25, 2012 Report Share Posted August 25, 2012 Does it tighten up ok? It seems like you'd have to slit down one side so it would actually tighten up. Nice work. Quote Link to comment
zenndog Posted August 25, 2012 Author Report Share Posted August 25, 2012 I did slit it, I will take a pic the next time I am in LA. I need to take off the air filter housing again to fix the tightening screw. The air filter housing has three bolts that hold it to the engine with brackets besides the screw that tightens the housing to the carb. Quote Link to comment
