DatMo Posted August 21, 2012 Report Share Posted August 21, 2012 I can't seem to find the place that sells the ignition key. Does anyone know where I can get one for cheap? Quote Link to comment
sedition88 Posted August 21, 2012 Report Share Posted August 21, 2012 Have you tried Nissan? You can always get a new ignition and it comes with two keys for it Quote Link to comment
ruckycharms Posted August 22, 2012 Report Share Posted August 22, 2012 evilbay (eBay) has lots of em cheap Quote Link to comment
yellowdatsun Posted August 22, 2012 Report Share Posted August 22, 2012 Any real locksmith will have one. Usually the old school type places. They can even find the single sided style, it's the same as the old Subaru's. Quote Link to comment
DatMo Posted August 22, 2012 Author Report Share Posted August 22, 2012 Any real locksmith will have one. Usually the old school type places. They can even find the single sided style, it's the same as the old Subaru's. thanks. ill be sure to look arond. ebay isnt exactly my preference Quote Link to comment
72dyme Posted August 22, 2012 Report Share Posted August 22, 2012 You live in Torrance, there should be plenty of places close by. If you can't find a place there, there is a place in Norwalk. Across the street from Norwalk square. Quote Link to comment
MikeRL411 Posted August 22, 2012 Report Share Posted August 22, 2012 Undefined model and year yields general comments. If you can narrow down your model and year, a quick trip to a locksmith [may be expensive] or a hardware store like Home Depot which has a key cutting machine can get the right key blank make and model. I have a 1967 Datsun and have several backup keys. I can give you the manufacturer and key blank number [single sided early key] if that would help. If you need hand holding [no offence just generic terminology] and can make one of the mostly Japanese classic car meets at the Torrance Home Depot, first Friday of each month, and let me know which meet you can make I can show you the various key maker part numbers that fit early single sided Datsuns, Help is really available make use of it. Quote Link to comment
merlin Posted August 22, 2012 Report Share Posted August 22, 2012 I have a bag of about 100 one sided key blanks for datsuns.... Quote Link to comment
DatMo Posted August 22, 2012 Author Report Share Posted August 22, 2012 Undefined model and year yields general comments. If you can narrow down your model and year, a quick trip to a locksmith [may be expensive] or a hardware store like Home Depot which has a key cutting machine can get the right key blank make and model. I have a 1967 Datsun and have several backup keys. I can give you the manufacturer and key blank number [single sided early key] if that would help. If you need hand holding [no offence just generic terminology] and can make one of the mostly Japanese classic car meets at the Torrance Home Depot, first Friday of each month, and let me know which meet you can make I can show you the various key maker part numbers that fit early single sided Datsuns, Help is really available make use of it. Thanks alot. Apreciate it.I actually went to home depot and they wanted $79 and they didnt even have the cut for it. It's a 68 Quote Link to comment
Dat510_Chris Posted August 22, 2012 Report Share Posted August 22, 2012 Had mine cut at a local locksmiths, $20 for a custom cut key Quote Link to comment
datsunaholic Posted August 22, 2012 Report Share Posted August 22, 2012 $79? $20? WTF? OK, so I don't have a '69, but I walked into Lowes with the only key I had and walked out with a new key for like $6, and I thought THAT was expensive. The hard part might be finding a blank, but I don't care if the key was a little long, and I certainly didn't need a factory Nissan blank. It's not an uncommon key form. My '72 510 used a DA22 aka 62DT blank, same as my '74 620 (they in fact share the same key). My '78 uses a DA24/62DU blank (they're opposite). My '83 uses a DA25 which is the same as a DA22 except the center groove is wider. Quote Link to comment
thatguy Posted August 22, 2012 Report Share Posted August 22, 2012 Most hardware stores like ace or true value (older school small ones) will be able to handle your business.......... Quote Link to comment
DatMo Posted August 23, 2012 Author Report Share Posted August 23, 2012 $79? $20? WTF? OK, so I don't have a '69, but I walked into Lowes with the only key I had and walked out with a new key for like $6, and I thought THAT was expensive. The hard part might be finding a blank, but I don't care if the key was a little long, and I certainly didn't need a factory Nissan blank. It's not an uncommon key form. My '72 510 used a DA22 aka 62DT blank, same as my '74 620 (they in fact share the same key). My '78 uses a DA24/62DU blank (they're opposite). My '83 uses a DA25 which is the same as a DA22 except the center groove is wider. I'll go to lowes. Thanks. Quote Link to comment
Shagy Posted August 26, 2012 Report Share Posted August 26, 2012 There is a place on Whittier right next door to a&g auto/audio. I took him my key code and they looked up the blank (stocked it) and cut me 2 keys on the spot. Was like $20 I think. I posted their info in my thread for keys. If your ignition is the same as your doors, take the passenger lock out and take it with you. Search posts made by me. I'm on my cell or id find the thread for you. Quote Link to comment
Shagy Posted August 26, 2012 Report Share Posted August 26, 2012 5747 Whittier Boulevard, Los Angeles, CA - its on the same side of the street....just use the cross walk and go west 20 feet. 1 Quote Link to comment
DatMo Posted August 26, 2012 Author Report Share Posted August 26, 2012 5747 Whittier Boulevard, Los Angeles, CA - its on the same side of the street....just use the cross walk and go west 20 feet. Is he a locksmith? Quote Link to comment
yellowdatsun Posted August 27, 2012 Report Share Posted August 27, 2012 The worse the locksmith shop looks, the better their old key selection usually is. So go into a few of the places that you wouldn't normally tread, you'll be surprised. 1 Quote Link to comment
Shagy Posted August 28, 2012 Report Share Posted August 28, 2012 Is he a locksmith? yeah. I was in and out in about 10 min. Really cool people. Quote Link to comment
Shagy Posted August 28, 2012 Report Share Posted August 28, 2012 http://community.ratsun.net/topic/31880-keys/page__st__20#entry480199 <- Place I got my Keys from. From this thread.. http://community.ratsun.net/topic/31880-keys/page__hl__keys Quote Link to comment
