uberkevin Posted March 11, 2016 Author Report Share Posted March 11, 2016 So i'm not understanding,,, are you saying the driveline one-ear gave you won't work either?? While I was at one-ears we started talking about drive lines, he said he has a bunch, so we walked into a back room and there lied About 10 drivelines he was calling 520s.. Before that I noticed a drive line laying in front of a 720 he had so I went and grab that one and lined it up with all the others on the ground All 11 of then we're the same size. Later I took the drive line he gave me to the u joint and set it down next to the other one I had left there. One that forsure came out of a 520 and put into a 521. And here's what happened. The one on the left is the one I got from one-ear. I'll be using the ugliest of the two. After they took the slip yoke off the end of it he told me to go back home and Re measure but put the yokE all the way in the transmission and measure from the middle of the u joint hole to the flange on my diff.. Everything will be fine. 2 Quote Link to comment
bananahamuck Posted March 11, 2016 Report Share Posted March 11, 2016 Ok,,, but if you shove the yoke all the way in then measure center to center,,, it will be to long won't it??? . I say that because when you install or remove a driveline ,, one must usually first push driveline yoke farther into transmission in order for it to clear the rear flange centering deal ( that circle on the flange) and be pulled out .. That's why i pulled it out a little over half inch before we measured it,, which is like about the minimum cuz alot of times it's more like 3/4" . Or am i reading what you wrote wrong?? 2 Quote Link to comment
flatcat19 Posted March 11, 2016 Report Share Posted March 11, 2016 I would think you don't want the yoke pushed in all the way when measuring. When your suspension compresses the drive line needs to go somewhere. No where to travel if it's pushed all the way in already. 2 Quote Link to comment
uberkevin Posted March 11, 2016 Author Report Share Posted March 11, 2016 Sorry I forgot to say that we had discussed him applying the 3/4in into the equation. After he told me to do that I asked about it and what not. Everything is fine. 2 Quote Link to comment
Charlie69 Posted March 11, 2016 Report Share Posted March 11, 2016 Here are the different ways to measure a drive line. and Naner is correct there needs to be 3/4" play on the slip yoke to accommodate The up and down movement of the driveline. The shop should be sizing for the rear end movement of 3/4". I use the Figure 3. Your driveline guy wants you to measure using Figure 1 with the yoke pushed all the way in, he will adjust for the rear end movement. I hope this helps. 5 Quote Link to comment
jrock4224 Posted March 11, 2016 Report Share Posted March 11, 2016 I would think you don't want the yoke pushed in all the way when measuring. When your suspension compresses the drive line needs to go somewhere. No where to travel if it's pushed all the way in already. which is most likely the culprit for tranny explosion v1.0.... that and driver input 2 Quote Link to comment
uberkevin Posted March 11, 2016 Author Report Share Posted March 11, 2016 Everything is fine, the 3/4 of an inch of play will be there. Also dick-muncher my other drive line had the 3/4 inch of play as well.... Two days before my tranny fucked up I drove an old guy about 45 minutes to Shelton and back into olympia to get some food from Safeway. Then down town to meet up with a coworker to grab some shot for work then alllll the way back home... Not one fucking problem. No horrible vibrations nothing... to this day I don't know why that shit happened.. Don't throat punch me.. 1 Quote Link to comment
jrock4224 Posted March 11, 2016 Report Share Posted March 11, 2016 for a second i thought you were telling naner the story sine he is widely known as thurston counties premier dick muncher 2 Quote Link to comment
uberkevin Posted March 11, 2016 Author Report Share Posted March 11, 2016 I miss you two being bff's. Why all the hair pulling and cat scratchin? 3 Quote Link to comment
flatcat19 Posted March 11, 2016 Report Share Posted March 11, 2016 Ugliest love triangle, ever. Naners, Kevin, and jrock. 3 Quote Link to comment
jrock4224 Posted March 11, 2016 Report Share Posted March 11, 2016 I miss you two being bff's. Why all the hair pulling and cat scratchin? naner is bi polar .. he came over last sat and was the nice sweet caring naner ... then his internet naner that u just wanna kick your tower over and punch a cat .. we are bff's he just pours it on extra thick cause i have him figured and i remind him as much as possible .. there's no beef .. im just responding to internet naner 4 Quote Link to comment
jrock4224 Posted March 11, 2016 Report Share Posted March 11, 2016 oh and a "fuck ted" for good measure ... but thanks for the coupe tails ted and the good deal .. 2 Quote Link to comment
bananahamuck Posted March 12, 2016 Report Share Posted March 12, 2016 Slipped in what?? 2 Quote Link to comment
jrock4224 Posted March 14, 2016 Report Share Posted March 14, 2016 Wow ted im joking relax ... you know we are close B) 1 Quote Link to comment
jrock4224 Posted March 14, 2016 Report Share Posted March 14, 2016 naner you too ... just relax ... 1 Quote Link to comment
uberkevin Posted March 14, 2016 Author Report Share Posted March 14, 2016 Tits yeah!! 1 Quote Link to comment
uberkevin Posted March 14, 2016 Author Report Share Posted March 14, 2016 Got some boomerangs for the Bday! To fucking windy to try to throw it to gt hit in the head. 3 Quote Link to comment
jrock4224 Posted March 14, 2016 Report Share Posted March 14, 2016 bring them to the shop i will toss them lol ... future head injury 4 Quote Link to comment
uberkevin Posted March 14, 2016 Author Report Share Posted March 14, 2016 I'll let you get hit in the head with them, forsure!!! 1 Quote Link to comment
]2eDeYe Posted March 14, 2016 Report Share Posted March 14, 2016 Any of those shafts about 62.5" long? 1 Quote Link to comment
uberkevin Posted March 14, 2016 Author Report Share Posted March 14, 2016 I'll have to get back to you on that. 2 Quote Link to comment
Cuevass4347 Posted March 15, 2016 Report Share Posted March 15, 2016 Oh I took off my door panels to make new ones, I haven't got to far on this just cut one of the new panels out of some thin plywood i got. I'm a really picky person about little shit so I know that I wont put something in my truck I don't like or isn't to my satisfaction. Like the dash board or these panels. here ya go. if your wondering what the thing in the back ground is? well its a home for this.. can u send me dimensions for door panels mine didn't come with any trying to make some out of thin plywood aswell 1 Quote Link to comment
Charlie69 Posted March 16, 2016 Report Share Posted March 16, 2016 Nice to see the lizard again. Looking thin on the legs. take a poop sample to a qualified vet and have it tested for parasites. Needs more light and calcium. Iguanas can be touchy too keep. Buttercup was skin and bones when I got here as a rescue. She had parasites, easy treatment of a milky looking liquid given to her 2 times and no more parasites. Quote Link to comment
hobospyder Posted March 16, 2016 Report Share Posted March 16, 2016 That picture is from 2013 Charlie. 2 Quote Link to comment
