bananahamuck Posted February 15, 2016 Report Share Posted February 15, 2016 If you run power directly to your coil on one side an tap a ground with the other side it should fire even without it hooked up any other way. .. don't leave hooked up very long just a few seconds to test. Yeah it could shock the fuck outta you if you hold it in your hand soooo find a way to run coil wire to engine ground,,,, or not,, and video tape it. :rofl: 1 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 The one that says Must stay on while cranking. It was in the ign spot on the ignition switch. But I used the test light and that post had constant power, and the post it's on now only has power while cranking 'test light' 1 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 If you run power directly to your coil on one side an tap a ground with the other side it should fire even without it hooked up any other way. .. don't leave hooked up very long just a few seconds to test. Yeah it could shock the fuck outta you if you hold it in your hand soooo find a way to run coil wire to engine ground,,,, or not,, and video tape it. :rofl: Not sure I understand, or even want to do that by my lonesome. 1 Quote Link to comment
bananahamuck Posted February 15, 2016 Report Share Posted February 15, 2016 I don't see why your old coil wouldn't work if you wire it up with jumper wires ....... My wife is still shopping and she took Alberts girlfriend so they may never come back 2 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 Hm. The l16 coil? The points coil!? 1 Quote Link to comment
hobospyder Posted February 15, 2016 Report Share Posted February 15, 2016 Wait............... Albert got a girlfriend? 1 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 Fuck! Spending hella money being gone so long. 2 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 Wait............... Albert got a girlfriend? He's had one for a while now! 1 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 So this isn't what my coil looks like. http://m.ebay.com/itm/1990-Nissan-240Sx-Ignition-Coil-W-Bracket-Oem-S13-5-Spd-Fb-5244-/191496960422?nav=SEARCH Also don't have the clip on the coil. And this is what I don't have. This may be the next step.. Scary turning over the motor, lube will only last so long. Hahaha 1 Quote Link to comment
hobospyder Posted February 15, 2016 Report Share Posted February 15, 2016 He's had one for a while now!yeah, I remember, still surprised 2 Quote Link to comment
Elkie Posted February 15, 2016 Report Share Posted February 15, 2016 If you turn ign on and start the wipers, do they stop when you start/crank? If they do then that yellow wire has to go somewhere else I think. 2 Quote Link to comment
uberkevin Posted February 15, 2016 Author Report Share Posted February 15, 2016 I'll test that tomorrow, thanks man! 1 Quote Link to comment
uberkevin Posted February 16, 2016 Author Report Share Posted February 16, 2016 Damn now I really don't know what to do.. shit. 1 Quote Link to comment
uberkevin Posted February 16, 2016 Author Report Share Posted February 16, 2016 Gunna pull some codes. http://www.240sx.org/faq/articles/ecmcodes.htm My ecu has no green bulb. Haha 1 Quote Link to comment
Draker Posted February 17, 2016 Report Share Posted February 17, 2016 You got this! 1 Quote Link to comment
uberkevin Posted February 17, 2016 Author Report Share Posted February 17, 2016 Started! For 1 second! I have a small proble, #2 injector is staying on.... sooo uhh... getting hella fuel in there.. started on 3 cylinders. Soon to be video. 1 Quote Link to comment
uberkevin Posted February 17, 2016 Author Report Share Posted February 17, 2016 6 Quote Link to comment
flatcat19 Posted February 17, 2016 Report Share Posted February 17, 2016 Getting there. Quote Link to comment
uberkevin Posted February 17, 2016 Author Report Share Posted February 17, 2016 My #2 injector is staying on tho!! Quote Link to comment
Draker Posted February 17, 2016 Report Share Posted February 17, 2016 Good start... you can do better! 1 Quote Link to comment
Draker Posted February 17, 2016 Report Share Posted February 17, 2016 Do those injectors use orings to seat in the fuel rail? Quote Link to comment
4perrev Posted February 17, 2016 Report Share Posted February 17, 2016 Nice work. Better say goodbye to those rear tires I'm sure. Temptation of the right foot is a good thing!! 2 Quote Link to comment
uberkevin Posted February 17, 2016 Author Report Share Posted February 17, 2016 Got the injector figured out.. someone had taped it in with the harness!! So now it's running on all 4 cylinders. Small bugs. Think I need to drop the oil pump and clock the dizzy back a notch or two. She dies after 10 or so seconds. I can't pull codes do to not having a green bulb in my ecu, but it would throw codes no matter what do to not having emissions shit.. #3 injector was leaking, fixed that. Exhaust is really going to be the big thing.. everything is really close to the torsion bar and the block/tranny. A had to cut my ebrake mount to. Overall it loud! And is nice as fuck to hear run. My dumb ass.. doesn't know if I got oil pressure tho..... I don't see why I wouldn't have but still.. I didn't hook up a gauge. 2 Quote Link to comment
uberkevin Posted February 17, 2016 Author Report Share Posted February 17, 2016 Do those injectors use orings to seat in the fuel rail? Both top and bottom there is a oring. Quote Link to comment
flatcat19 Posted February 17, 2016 Report Share Posted February 17, 2016 Dies after a few seconds...you left the IACV hooked up, right? The IAC is the only thing you should have left on when deleting emission stuff. Quote Link to comment
