SR20DET swap questions
onekickkawi
I am about to install the SR20DET engine in to my 510 but before I do I have a few question on if I can remove some items.
  1. Do I need to use the IAA (idle control valve) on the intake manifold?
  2. Do I need to use the coolant lines that go to the throttle body?
  3. I have the Can/AM box from and I understand the wiring box, however it doesn’t specify what part of the harness to pull the wires from.
  • Replies 6
1. Yes and No, simple google search will basically tell you that your SR will run like shit.
2. No, but it will help with cold starts.
3. Should be a pretty straight forward install. The wires needed are the ones cut near the ecu plug. Read this http://community.ratsun.net/topic/537-how-to-wire-a-ka-ca-sr-and-vg-into-anything/
I love the
3. Should be a pretty straight forward install. The wires needed are the ones cut near the ecu plug. Read this http://community.rat...-into-anything/
I LOVE the "how to wire" thread, but at the same time I'm thinking it needs to be cleaned up and condensed REALLY bad lol.
