thisismatt Posted August 13, 2012 Report Share Posted August 13, 2012 I need a set of 2wd 720/620 lower arms with torque arms (the piece that connects the torsion bar to the arm), tension rods, & just the 720/620 upper arm cross rods (narrower than the hardbody equivalent). Don't need hubs but I'd take them if you just want to get rid of them. I don't need rotors, calipers, or spindles.Shoot me a PM with any offers, thanks! Link to comment
Eagle_Adam Posted August 14, 2012 Report Share Posted August 14, 2012 i have a parts truck your welcome to come cannibalize PM me Link to comment
thisismatt Posted August 28, 2012 Author Report Share Posted August 28, 2012 got some nibbles, but still lookin Link to comment
Eagle_Adam Posted September 10, 2012 Report Share Posted September 10, 2012 sorry matt, the truck sold whole. HOWEVER, i should have a 77 coming to me soon, you can have 1st dibs if your interested PM me Link to comment
nis720 Posted September 11, 2012 Report Share Posted September 11, 2012 I have a pair of HB hubs and 720 hubs... $50 for each pair. Β Old pic of the HB hubs Β Link to comment
thisismatt Posted September 12, 2012 Author Report Share Posted September 12, 2012 I have a pair of HB hubs and 720 hubs... $50 for each pair. Β Old pic of the HB hubs Β I got some 720 hubs, but I will keep you in mind if they don't work out. Thanks! Link to comment
yello620 Posted September 18, 2012 Report Share Posted September 18, 2012 Matt, i have a single upper control arm from an 80 720. Its listed here.http://community.ratsun.net/topic/47156-too-many-620-parts-they-need-a-new-home/ Link to comment
thisismatt Posted September 20, 2012 Author Report Share Posted September 20, 2012 Matt, i have a single upper control arm from an 80 720. Its listed here.http://community.rat...eed-a-new-home/ I'd only need the cross rod w/hardware, and then I'd still need the other side's :P Thanks, though Link to comment
thisismatt Posted September 28, 2012 Author Report Share Posted September 28, 2012 bump bump - still haven't acquired lower arms, upper cross bars, nor tension rods Link to comment
thisismatt Posted January 3, 2013 Author Report Share Posted January 3, 2013 Bump cause I'm still lookin for these parts... Link to comment
wayno Posted January 4, 2013 Report Share Posted January 4, 2013 Bump cause I'm still lookin for these parts... Β I am curious, what are you looking to fabricate, a disc brake 521 front end? Link to comment
thisismatt Posted January 4, 2013 Author Report Share Posted January 4, 2013 I am curious, what are you looking to fabricate, a disc brake 521 front end? Maaaaybe ;) Link to comment
wayno Posted January 4, 2013 Report Share Posted January 4, 2013 You know that I did just that about ten years ago, and one thing I would recommend you do if you are bound and determined to do this, the upper control arm mount bolts need to be drilled and re-threaded to use the 720 UCA mount bolts, I have had my 521 UCA mount bolts break several times, usually when I hit the brakes, once going around a corner, but I might have touched the brakes that time also, it really sucks when the front end falls out from under you. It is possible to do it, as I have done it, but I will be retiring this frame in the next year or so, as I am tired of the issues, and it is so easy to drop the 521 cab onto a 720 frame, and likely would be easy to drop it onto a 620 regular cab short box Β frame with disc brakes also, I like the 720 frames because they came with a power steering option. Another thing I figured out is that you cannot make an upper control arm at the same angle as the kingpin upper control arm, that upper balljoint has to be farther back. I have done this, I usually talk people out of it, I beleave I have a 100% success rate so far. Β I have never had it happen yet, but it could get real ugly fast if one or both of them UCA bolts break going hiway speeds. Link to comment
