Bambino Posted August 9, 2012 Report Share Posted August 9, 2012 ive changed out all my wheel cylinder, in all 4 drums, and I've bleed the brakes for the 5th time and I got nothing yet... I need help plz Quote Link to comment
Eagle_Adam Posted August 9, 2012 Report Share Posted August 9, 2012 have you bled the master cylinder and do you have a FSM? Quote Link to comment
Bambino Posted August 9, 2012 Author Report Share Posted August 9, 2012 no I haven't bled that master cylinder.. and not sure what the fsm is??.. Quote Link to comment
Bambino Posted August 9, 2012 Author Report Share Posted August 9, 2012 im only 19.. it's my first car, my uncle had it sitting for 8 years.. and I brought it back to life. runs great. better than before, it's just the brakes stopping me from driving it everyday. Quote Link to comment
Eagle_Adam Posted August 9, 2012 Report Share Posted August 9, 2012 ok, here is your break from someone who was a noob not to long ago. FSM = Factory Service Manual Post some pics of your truck - everybody likes to see what your working on and sometimes can point out issues just by looking Do you have any repair manuals? Quote Link to comment
banzai510(hainz) Posted August 9, 2012 Report Share Posted August 9, 2012 OK put your finger on the hole in the master cylinder and have soembody pump the master up . hopfully it will shoot soem fluid UP at you. Then if it does try going to the wheel cyl and see if it starts comming out there. If Not, the master could have gone bad as you one pushes the Master in theres a ridge inside that breaks the O ring or seal cause your were pushing the pedal all the way to the floor past the rideg in side the master cly bore thus ripping the seal With all wheel cyl closed and fluid in Master when you push the pedal do you see tiny air bubbles come up in the resivoir ? If yes then its Bad I would say. ck inside the cab to see if leaky from inside????? If was dry it could have cracked a seal ? I have never bleed a maaster cylinder in 25 years of owning a Datsun myself Quote Link to comment
Bambino Posted August 9, 2012 Author Report Share Posted August 9, 2012 ok, here is your break from someone who was a noob not to long ago. FSM = Factory Service Manual Post some pics of your truck - everybody likes to see what your working on and sometimes can point out issues just by looking Do you have any repair manuals? yeah I got one Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Suspect master cylinder. Diag it as Hainz suggests. Quote Link to comment
Eagle_Adam Posted August 9, 2012 Report Share Posted August 9, 2012 I have never bleed a maaster cylinder in 25 years of owning a Datsun myself Ive done it on the last few ive worked on and its made a hell of a difference O_o yeah I got one Chilton or haynes - not that it matters Quote Link to comment
datzenmike Posted August 10, 2012 Report Share Posted August 10, 2012 ive changed out all my wheel cylinder, in all 4 drums, and I've bleed the brakes for the 5th time and I got nothing yet... I need help plz Got nothing? What does this mean? You still have no brakes or no fluid is coming out? You only changed the wheel cylinders so you don't need to bench bleed the master. Well as long as it hasn't gone dry. Keep the master full of fluid, open the bleeder rear right side, have someone push the peddle down, close bleeder, raise peddle... repeat until fluid pushes all the air out and only clear fluid squirts. It may take 7-8 pumps to fill the wheel cylinder and the line to it. Now the left rear, right front and left front. Be sure to adjust the brake shoes to the drums to reduce travel. Quote Link to comment
Bambino Posted August 10, 2012 Author Report Share Posted August 10, 2012 I got Haynes Quote Link to comment
Bambino Posted August 10, 2012 Author Report Share Posted August 10, 2012 yeah.. we done that mike. but it doesn't seem to work. I've the shoes adjusted all the way to the drums thinking that'll help but still doesn't work. Quote Link to comment
datzenmike Posted August 10, 2012 Report Share Posted August 10, 2012 OK then loosen the front line coming out of the master and have someone depress the peddle... fluid should seep out if it's actually moving Quote Link to comment
ggzilla Posted August 10, 2012 Report Share Posted August 10, 2012 +1. Even if the brakes are not adjusted (or even missing), Mikes test will show if the Master Cylinder is working or not. Sometimes even rebuilt units are bad right out of the box. Quote Link to comment
rayven14 Posted August 10, 2012 Report Share Posted August 10, 2012 Im keeping a close eye on this forum, I'm having the same problem. I got brand new front and rear calipers, brake booster and new master and still I got crap!!! nothing!!! zilch!!! zero!!!! nada!!!! Im gonna try to bleed the system AGAIN!!!! and see what happens. Its days like this that I wanna ditch the whole freakin project. Quote Link to comment
ggzilla Posted August 10, 2012 Report Share Posted August 10, 2012 First bleed the master cylinder. Quote Link to comment
rayven14 Posted August 10, 2012 Report Share Posted August 10, 2012 I've bled that damn thing more times than I care to think about. got nice clean fluid coming from all wheel cylinders but still ... nothing. My only guess is that I have a major air pocket in on of em. Quote Link to comment
ggzilla Posted August 10, 2012 Report Share Posted August 10, 2012 Good, fluid comes out of the wheel cylinders when you pump the pedal. That's very good. Now you need to adjust the master cylinder pushrod, per the repair manual instructions and she'll work correctly. Quote Link to comment
rayven14 Posted August 10, 2012 Report Share Posted August 10, 2012 :confused: Dude... What!?!?!!?!?!? Quote Link to comment
rayven14 Posted August 10, 2012 Report Share Posted August 10, 2012 Can I get an OIC, I have a repair manual but it doesnt go over that part of the equation. Quote Link to comment
banzai510(hainz) Posted August 10, 2012 Report Share Posted August 10, 2012 Do what GGZilla said and see what that does However, You never anwsered in post 6 . With all wheel cyl closed and fluid in Master when you push the pedal do you see tiny air bubbles come up in the resivoir ? If yes then its Bad I would say. Im just saying with not resisitance the master might be able to push fluid with bleed open . But closed it might not. This happen to me after WHEEL CYLINDER CHANGE. MASTER went bad trying to bleed it. can buy a couple and keep as a sparee http://www.rockauto.com/catalog/raframecatalog.php Quote Link to comment
ggzilla Posted August 10, 2012 Report Share Posted August 10, 2012 Different guy, different problem. rayven14 Bambino is the original poster. Quote Link to comment
rayven14 Posted August 10, 2012 Report Share Posted August 10, 2012 I feel like Im thread jacking but I guess since its all relative information ...its ok. I get some pressure but the pedal still goes down all the way, not quite to the floor but close. Quote Link to comment
banzai510(hainz) Posted August 10, 2012 Report Share Posted August 10, 2012 Yes still awsering Babino Im keeping a close eye on this forum, I'm having the same problem. I got brand new front and rear calipers, brake booster and new master and still I got crap!!! nothing!!! zilch!!! zero!!!! nada!!!! If Rayven You need to be spefic on wht you got on the 510 esp if you got rear disc installed as depedning on kit you can mount them upper or lower and have to bleed them correctly. Also you got power brake master cylinder? Quote Link to comment
rayven14 Posted August 10, 2012 Report Share Posted August 10, 2012 Okay... I got Chevy Corvette Calipers on the front with top mounted bleeders Nissan 280zx calipers on the rear that also have top mount bleeders as well as the power brake master cylinder, I believe my application (while new) came from the B210 not sure what year I have bled both the master cylinder (three times) and all four corners twice, I do have some resistance in the pedal but again the pedal still goes near the floor when I push it. As a side note it used to hit the floor, now it just comes close. Anybody wanna buy a 73 wagon? Im kidding unless I can get this crap figured out. Quote Link to comment
