mklotz70 Posted March 26, 2013 Report Share Posted March 26, 2013 I'm pretty much done with the design of this thing! I put most of the pics up on my belt sander thread....... http://community.ratsun.net/topic/17029-mklotz70-belt-sander-build/page-7#entry883044 .....if you go to the previous link, I posted some pricing info if you're curious. Quote Link to comment
mklotz70 Posted March 31, 2013 Report Share Posted March 31, 2013 I'm not going to put all the CAD stuff here....a bunch will be put in the grinder thread. Gotta love CAD!!! I was working on making a 10" contact wheel work. I wanted it to work on the same arm as the 8". I thought I had it figure out, but as you see in the 2nd pic, there's a bolt head interfering. So, I figure out that with the 4" drive wheel, I can get it to work just fine on the same arm as the 8". edit:.. DOH! They posted in reverse order.....start at the bottom pic and work up :) Quote Link to comment
mklotz70 Posted April 16, 2013 Report Share Posted April 16, 2013 Finally got a bit more time on the Envelope machine parts.... Quote Link to comment
mklotz70 Posted April 20, 2013 Report Share Posted April 20, 2013 Going to make a drill jig to drill a second hole in several hundred brackets at work. Figured I'd create it in CAD first :) The silver piece is the bracket that gets the second hole(which is shown in the bracket already) The knobs will line up with the slots in the small drill press at work so that it can be clamped into position. Quote Link to comment
mklotz70 Posted April 27, 2013 Report Share Posted April 27, 2013 Maybe I should just start my own thread since I seem to be hogging this one. Since I posted the CAD work, I thought I'd put up a few pics of the finished project. I had a piece of aluminum here, but it wasn't quite as wide, so I decided to have just the backstop. Seems like it will work really nicely. Basically, we'll use a bracket that has the hole in the correct place, use it to align the jig, then tighten the jig to the drill press table. The the brackets with one hole can be dropped on the pin, pushed to the backstop, drilled, removed, repeated. :) Quote Link to comment
mklotz70 Posted May 10, 2013 Report Share Posted May 10, 2013 I'm in the process of reworking my truck kit. I've had this idea for awhile and wanted to explore the option before the last batch was made....but time wasn't on my side. I've run out of kits again and I'm not doing any more until the ball joint mod is done. I'm not sure how much of this project's CAD work I'll put here. I may start another thread for it.....but this is convenient for now. I'm not finished with the spindle model, but it was close enough for this. The caliper/ring thing is a temporary part to help with alignment and placement. Maybe at some point, I'll have time to model the rest of the hub/rotor/caliper, but for now, I just needed a way to figure out the new shape of the main plate. Obviously, the main plate clears the single piston caliper I've been using for years. This is an exploration into whether I can use the 2 piston on the HB rotor....which is a good bit smaller than the Passport rotor it's typically used on. I'm pretty sure the caliper bracket will hit the top hat of the rotor, but I'll worry about that a bit later. Anyway........you can see the over lap of the bracket on the main plate in these 2 images. I can now modify the main plate and know that it will clear. :) The added benefit was that as I was trying to put the spindle and plate together, I found out that the holes in my plate were off by a few thou.....have been for years I guess. lol Quote Link to comment
mklotz70 Posted May 10, 2013 Report Share Posted May 10, 2013 ....so a bit more playing.... I put the clearance dips back in the longest straight by the caliper to make sure it would still clear the single piston. I then figured out how to position the main plate holes so that I can use the same tab instead of 2 different ones like the old bracket. Out of time for now.... 1 Quote Link to comment
]2eDeYe Posted May 10, 2013 Report Share Posted May 10, 2013 The added benefit was that as I was trying to put the spindle and plate together, I found out that the holes in my plate were off by a few thou.....have been for years I guess. lol Funny how the real world works even when a little out of tolerance :lol: 1 Quote Link to comment
mklotz70 Posted May 10, 2013 Report Share Posted May 10, 2013 I'm a bit out of whack and my wife still tolerates me.........is that what you mean? :) 1 Quote Link to comment
mklotz70 Posted May 10, 2013 Report Share Posted May 10, 2013 ......hide the extra stuff, throw in some temp spacers since I don't know what the offset will be yet. I'm considering this for the next batch.......plug welding the tabs to the spacers. Quote Link to comment
mklotz70 Posted May 31, 2013 Report Share Posted May 31, 2013 I didn't want to keep hogging this thread, so I put the 411 design pics here if anyone is interested :) http://community.ratsun.net/topic/10125-410411-disc-brake-mod/?do=findComment&comment=929469 Quote Link to comment
mklotz70 Posted June 30, 2013 Report Share Posted June 30, 2013 Latest CAD work. Not quite done, but I think it's all figured out. Still more CAD work to do. Not sure if I'm making it or not. No plans of production....just a one off set. This fits on the 521 kingpin spindle. :) 2 Quote Link to comment
