Great Parts, for 510. Engine, Electrical, Interior, ETC.
Starter
(DATSUN 510 L SERIES STARTERS
CORRECT FOR THE 1970 TO 1973 MODEL YEARS)
$50
Distributor w/ Spark Plug Wires
$125
Front Cover
$110
Timing Chain
$35
Oil Pump (new and used)
$70 & $50
Timing Gears
$30 (have one left)
Fuel Pump
$25
Thermostat Housing
$15
Water Pump Pulley
$10
2) Rocker Arms
$10
Carb Gaskets
$10
1971 Alternator
$25
Cooling Fan
$15
  • Replies 43
Any chance you would be in the Ontario or pomona area? Are the pistons flat tops? do you still have the header?
Unfortunatly,
No I am rarely in that area.
The pistons are flat tops, and i do have the header.
Regards,
Josh
(626)487-1565
