bryant2482 Posted July 31, 2012 Report Share Posted July 31, 2012 hey guys im curious if anyone knows how many mpg's a z24 with a weber 32/36 will get? high way and stop n go speeds? i like to cruise between 35-45 mph and my engine runs from 2000-2400 rpms and highway almost 3000 rpms Quote Link to comment
jesusno2 Posted July 31, 2012 Report Share Posted July 31, 2012 18 to 20 if your lucky Quote Link to comment
datzenmike Posted July 31, 2012 Report Share Posted July 31, 2012 2wd anywhere up to 25MPG, 4x4 under 22 Quote Link to comment
HRH Posted July 31, 2012 Report Share Posted July 31, 2012 25 mpg if you're geared correctly and the Weber is jetted leaner. Stock stump pulling gears, 18-20 is about right, even for 2wd. The 3000 rpms on the freeway is what will kill you. Unlike EFI, you're open on both barrels at 3000 rpm. If you lean that out (smaller main jets) you'll have less power, but certainly better economy. Quote Link to comment
ggzilla Posted July 31, 2012 Report Share Posted July 31, 2012 Jet it right -- about 14.7 for cruising. You'll still have beaucoup power when you floor it, because the Weber has a power valve. Quote Link to comment
datzenmike Posted July 31, 2012 Report Share Posted July 31, 2012 Beaucoup. Ah the great French diaspora... America and Canada can claim the first and second largest population of French decedents outside France itself. Quote Link to comment
