blueghost510 Posted July 30, 2012 Report Share Posted July 30, 2012 I posted on there the other day and had tremendous luck getting my motor running... Now it's not running right. Under load it runs rough and then stalls out, and the "charge light" is on. I check the alt, and it's charging. I was going to go though and double check for vac leaks, since I removed all the smog junk. New fuel filter. Any ideas? I know the carb is good, I pulled it off a motor that I was driving last week.... Quote Link to comment
DAT510 Posted July 30, 2012 Report Share Posted July 30, 2012 For the charge light, check to see if the voltage reg works. A bad voltage regulator will give you the charge light. Check voltage at battery at various RPMs. shouldn't be above 14 volts. Quote Link to comment
banzai510(hainz) Posted July 30, 2012 Report Share Posted July 30, 2012 Ck the timming again. adjust the fuel mixture? ck the throttle cable? ck voltage with digital volt meter. this is a simple fix Quote Link to comment
blueghost510 Posted July 30, 2012 Author Report Share Posted July 30, 2012 Thanks for the advice. I'm going to get out there now and start plugging way. Ryan Quote Link to comment
