ltamay7 Posted July 29, 2012 Report Share Posted July 29, 2012 Hi, I have a 72 510 and I would like if someone could please tell me what engine size this car has wit this numbers I found on the block; or direct me how to find out, L203 525580. thanks! Quote Link to comment
DAT510 Posted July 29, 2012 Report Share Posted July 29, 2012 That "3" is actually a B im willing to bet. Quote Link to comment
john510 Posted July 29, 2012 Report Share Posted July 29, 2012 L20B,its not the motor that came in that car from the factory.Just under 2000 cc's.Stock would have been L16,1600cc. 1 Quote Link to comment
ltamay7 Posted July 29, 2012 Author Report Share Posted July 29, 2012 you are right! it's a B, does that means it's a 2.0 L ? Quote Link to comment
DAT510 Posted July 29, 2012 Report Share Posted July 29, 2012 you are right! it's a B, does that means it's a 2.0 L ? Indeed, well 1986 cc's I think. but a 2 liter. what about the head? the casting mark should be on the spark plug side, right above the block. should be something like U67 or 210 or V912, the V912 head is garbage and you should totally give it to me. Quote Link to comment
ltamay7 Posted July 29, 2012 Author Report Share Posted July 29, 2012 ok, thanks! I'll check the other markins later and consider your offer..! lol Quote Link to comment
ltamay7 Posted July 29, 2012 Author Report Share Posted July 29, 2012 the head mark it's A87 what that means..? Quote Link to comment
DAT510 Posted July 29, 2012 Report Share Posted July 29, 2012 the head mark it's A87 what that means..? It's just the casting mark on what the head is, from there you can tell valve sizes, intake/exhaust port sizes.. etc. Though the only thing you can't tell with out taking the head off is whether it is a closed chamber or open. Open and closed respectfully: You see how one is a full circle, and one is kidney shaped? Here is all the info on L4 heads. http://olddatsuns.com/ Go to SSS heads and scroll down to the chart. Quote Link to comment
ltamay7 Posted July 29, 2012 Author Report Share Posted July 29, 2012 ok, thank you very much for all the information! you guys are good! Quote Link to comment
