DREWSDIME Posted July 27, 2012 Report Share Posted July 27, 2012 I have member who needs winshield for 70 521 my friend is selling 72 521 winshield will it fit??? Quote Link to comment
DREWSDIME Posted July 27, 2012 Author Report Share Posted July 27, 2012 Thank you! Quote Link to comment
DREWSDIME Posted July 27, 2012 Author Report Share Posted July 27, 2012 Easiest way to remove from truck and save rubber seal? Quote Link to comment
MicroMachinery Posted July 27, 2012 Report Share Posted July 27, 2012 I'm not sure if saving the seal is easily done.. I think the easiest way to remove the glass with the seal intact is taking a sawzall to the A pillars, roof, and cowl.. as old as the seals are, I don't think it's doable otherwise. That's probably not much help. Quote Link to comment
Royal Sierra Posted July 27, 2012 Report Share Posted July 27, 2012 Would a 620 winshield fit a 521 Quote Link to comment
DREWSDIME Posted July 27, 2012 Author Report Share Posted July 27, 2012 I dont think so Quote Link to comment
DanielC Posted July 27, 2012 Report Share Posted July 27, 2012 Wayno might have some new 521 windshield weather strips. Quote Link to comment
Royal Sierra Posted July 27, 2012 Report Share Posted July 27, 2012 Thought so. Itd be good to be true Quote Link to comment
wayno Posted July 27, 2012 Report Share Posted July 27, 2012 If the gasket/seal is old, you will be taking a chance on getting the window out undamaged trying to save the seal. I just use a razor blade on the inside, I cut the seal on the sides and top, and then push/lift the windshield out. If the seal is flexible, I start in one of the corners and push the seal onto the otherside of the metal holding it in there an eighth inch at a time, it takes forever, I have no idea how them glass guys get it out complete in less than 5 minutes without breaking anything. Installing them is much easier than removing them in my opinion. I do have 520/521 windshield gaskets(molded corners) for $105.00 plus shipping($15.00), I will have a few with me at the "blue lake" show/meet. Quote Link to comment
