skyknight789990 Posted July 21, 2012 Report Share Posted July 21, 2012 ok i got a problem i have been trying to track down in my truck just started out of no where my fuse blew for my running lights an nothing was changed on the truck i know its a short or something somewhere an i am not big on wiring on vehicles but i have unhooked all my lights to check them...my brake lights turn singals an 4ways all work with no problem but i cant turn on my running lights an i need them due to working swing shift can anyone help me with my truck Quote Link to comment
datzenmike Posted July 21, 2012 Report Share Posted July 21, 2012 Under the pass side seat is a 10 pin connector that connects the cab harness to the rear frame harness. If you unplug this and the problem goes away you will at least know the problem is from there back. I had a similar problem on my 521... turned out someone in the past had spliced into the rear harness for a trailer light hook-up and removed it and hadn't properly taped the wires up. Naturally salt water in the winter got in and rotted the wires. Quote Link to comment
banzai510(hainz) Posted July 21, 2012 Report Share Posted July 21, 2012 I alwasy try cleaning the connections at the fuse holders reconnect and disconnect the plug this might help cleaning up your contacks Quote Link to comment
skyknight789990 Posted July 22, 2012 Author Report Share Posted July 22, 2012 i dont think i have a connection problem i am blowing fuses an there was a 25 amp fuse in there ill give it a try though an see if it fixes it Quote Link to comment
ggzilla Posted July 22, 2012 Report Share Posted July 22, 2012 Unplugging the connection is a way to troubleshooting -- to narrow down the cause. It is not a fix. Protect your wiring harness by using the stock fuse. Do not put a higher-rated fuse than stock. Quote Link to comment
skyknight789990 Posted July 22, 2012 Author Report Share Posted July 22, 2012 ok thanks Quote Link to comment
banzai510(hainz) Posted July 22, 2012 Report Share Posted July 22, 2012 sometimes a high resisitance will cause a overdraw of current. I dont know why you think it would be oppisite. But I had a fuse to my alternator rechrge circut kept popping the fuse. I reaseated the instrument panel plug in then it went away. Quote Link to comment
