zed Posted July 16, 2012 Report Share Posted July 16, 2012 when I rebuilt my L18 I re-used the old main bearing side seals - because I couldn’t get the new ones into the grooves in the main bearing cap – probably my inexperience, but even with a pin punch and hammer they were too tight to go in. So, now 40k miles later I’ve got a serious oil leak down the engine plate between the block and the bell housing.(I’m assuming it’s the main side seals and not the rear main seal gone bad) I want to try a fix with the motor in the vehicle. I see it has been done on Datsuns - see http://www.classiczcars.com/forums/thread41742.html I would appreciate any warnings or tips on the job? I’ve got a tube of Locktite Grey silicone - which everyone says is the best - and a new set of side seals. But if I couldn’t get it right with the motor on the bench, what are my chances of getting it right while lying under the truck with oil dripping in my face! thanks for any advice Quote Link to comment
banzai510(hainz) Posted July 16, 2012 Report Share Posted July 16, 2012 if you have the stock oil sender make sure its not that . Mine I thought it was it buy oil was wondering back and down to make it look like a rear main seal. Nissan still has the side seals and its the 1 prc units unlike the 2pc with is a rubber and a pc of metal. 12289-W0400 Quote Link to comment
zed Posted July 18, 2012 Author Report Share Posted July 18, 2012 thanks Hainz. My seals are two pieces - one on each side of the bearing cap. I got the oil pan off, and I can't see if it's the side seals or maybe the rear crank seal. The oil dripping in my eyes didn't help! Quote Link to comment
medengines Posted July 22, 2012 Report Share Posted July 22, 2012 the way i do it is with the cap off..put a light dab of RTV where the seal will contact block..i set the seals up in place and with seals sticking down lower than the bottom of cap..."about half way out the bottom of cap"..get your cap in place and aligning your bolt holes slide it in place and evenly tap in slowly with a plastic hammer(i use steel) lightly tap into place... when you've got it close enought to bolt holes use the cap bolts to "pull it down" to block slowly and evenly...the seal will touch the block and come up on it's own!! walla your done! this way is the best i've gotten it to work for me! trying to tap them in after torqing the cap in place hasn't worked out good for me.. 1 Quote Link to comment
zed Posted July 22, 2012 Author Report Share Posted July 22, 2012 ^ exactly what I was looking for! I knew there must be a trick to it. Thankyou Quote Link to comment
Sealik Posted July 22, 2012 Report Share Posted July 22, 2012 Also...take notice of the position of the cap. I should be flush with the back of the block....but....install as it was prior The side seals are slightly longer than needed....and will need to be trimmed flush As seen with the seal on the right If the cap isn't removed yet....here's a little trick Bolt in the center....prybar Quote Link to comment
Dimerforlife13 Posted July 23, 2012 Report Share Posted July 23, 2012 I personally have always just had a tube of black silicone that goes in a caulking gun, cut a nice 45 deg. tip, an fill those voids with just silicone, until you can see light through it. Never had a problems with it, and have done more than a few motors. You have to use a caulking gun though, use a far amount of pressure, works great... Quote Link to comment
ggzilla Posted July 23, 2012 Report Share Posted July 23, 2012 Yes, use RTV -- like Nissan started using in the 1980s. Quote Link to comment
zed Posted July 23, 2012 Author Report Share Posted July 23, 2012 thanks for the advice! Quote Link to comment
zed Posted July 31, 2012 Author Report Share Posted July 31, 2012 dropped the pan, did the repair, just got back from a 500 mile journey with a trailer - not a drop leaked. thanks Ratsun! Quote Link to comment
