pl521sss Posted July 6, 2012 Report Share Posted July 6, 2012 Regretfully selling my VQ35 powered 510. I crashed it a few months ago and now decided to sell. Too many toys, not enough time, resource and money. Asking $6000 I may consider trades like 68 sedan or a 411\410 wagon or sedan Here's the specs Engine: VQ35DE from a 2006 G35 6 Spd transmission (CD008) Vqswap shifter relocator (moves the shifter forward) Custom Engine Mount brackets (uses stock rubber mounts, the engine is amazingly completely motionless under load, no twisting) XTD Chromoly lightweight Flywheel OEM clutch & pressure plate Braided Stainless Steel clutch line Modified Intake manifold/Upper plenum to have a larger neck & support a Performance Products 85mm Throttle-body (stock is 70mm) 4? intake piping AEM EMS tuned AAM Angled Plenum Spacer (good for 5-10hp) Rewired with a 240sx fuse box Reversed front crossmember Relocated Battery (behind passenger seat) Fuel System: RCI 15 gallon Fuel Cell Custom Surge Tank Walbro 240lph high pressure pump Mallory 90gph low pressure pump 8AN fuel filters 8AN & 6AN stainless steel braided Fuel lines with Earls, Russel, & Aeroquip fittings Injected Performance Fuel Rails SX adjustable fuel pressure regulator with pressure gauge Cooling: Oil Cooler with Greddy Sandwich Adapter with thermostat Steel Braided 10an oil lines Afco Sirrocco style dual pass aluminum radiator Exhaust: Modified OEM exhaust manifolds (all stainless steel) 2 1/4? stainless piping to 3? aluminized steel pipe 3? resonator & 3? Magnaflow muffler (no catalytic converters) The car sounds great, with the definitive VQ exhaust note Drivetrain: Custom Driveshaft 3.7 ratio R200 Differential with Z32 finned cover & new bearings MadDat R200 conversion Mustache bar OBX Helical LSD (the LSD design faults & weaknesses have been fixed) Shortened Z31 Turbo CV axles (also very strong) Modern Motorpsorts Billet Companion Flanges 280z Stub Axles (known for strength) new bearings as well Interior: Sentra SER seats Custom carbon fiber dash with Autometer gauges Tach & Speedometer are Ultra-lite series The remaining are Lunar series (fuel level, oil pressure, water temp, voltage) AEM wideband sensor with gauge RCI seat harnesses Door panels & rear seats are in good shape Headliner in good condition Dash Pad is near perfect Exterior: Advan SA3R wheels, 16x7?s up front with 16x8?s In the rear BF Goodrich G-Force KDW T/A tires (nearly new) 205front, 225rear Hella/BMW headlight conversion with relays Hood shocks Carbon Fiber rear view mirrors Suspension/Steering: Koni Yellow?s in the rear with Ground Control Springs (approx. 950lbs.) Koni Red?s in front with 325lb Ground Control Springs, spare 275lb set 200sx V6 front struts Techno Toy Tuning tension rods Penultimate Rear crossmember Cusco Camber Plates Bumpsteer Spacers Techno Toy Tuning Spring perches with bearings up front Modified Rear LCA?s for added rear wheel clearance Custom Rack & pinion steering rack using a BMW manual rack Brakes: Z32 4 piston Calipers in front with 11.5? vented rotor Z32 2 piston Calipers in rear Most of the Brake hardlines are new Stainless steel braided flexible lines Wilwood brake bias adjuster (in cabin) 280zx 15/16 Brake Master Cylinder Security: Python Pager Car Alarm Here's the damaged side of the car I hit a small tree Link to comment
fo0manchu Posted July 6, 2012 Report Share Posted July 6, 2012 dang, hammer that out and drive it! Link to comment
xlr8r Posted July 6, 2012 Report Share Posted July 6, 2012 EEEEK!!! My baby got a booboo. Sad to see. I assume the back end decided to kick out on you when you gave her some gas. It will be a lot of good stuff to swap over to a clean chassis, or repair the quarter if the car is still straight. Link to comment
kgb Posted July 6, 2012 Report Share Posted July 6, 2012 Abe getting sideways!!! First Adrian and his wagon now this? Whats going on over there?!? Link to comment
pl521sss Posted July 6, 2012 Author Report Share Posted July 6, 2012 Yup It sucks and happens I wish didn't take it out that day. Link to comment
sr71sss Posted July 7, 2012 Report Share Posted July 7, 2012 we have the technology to rebuild it, just do it Link to comment
Moore Racing Posted July 9, 2012 Report Share Posted July 9, 2012 very interested please call. 408 636 83 six one Link to comment
510mango Posted July 15, 2012 Report Share Posted July 15, 2012 Is the car still available. I fallowed the build thread on this car on 510realm and have always loved it thanks. Link to comment
