nissan720 Posted July 3, 2012 Report Share Posted July 3, 2012 r the windsheilds in the 1984 and 1985 nissan truck the same.,the nssan parts zone do not have a tech support?say the wheather strip is not available for 84,but its available for the 1985. Quote Link to comment
SHORTDOG Posted July 4, 2012 Report Share Posted July 4, 2012 Yes, they are the same. The only difference is one gasket takes the chrome molding and one doesn't, be sure to order the right one. Quote Link to comment
nissan720 Posted July 4, 2012 Author Report Share Posted July 4, 2012 okay thank u. Quote Link to comment
datzenmike Posted July 4, 2012 Report Share Posted July 4, 2012 From 06 '83 and up ('84 model year and up) there are two windshields used, the only difference is clear or tinted. They are ... 72712-S3500 Tint (made in USA) 72712-S3501 Clear (made in USA) Beginning 07 '84 ('85 model year) The ST option truck had a windshield with an antenna in it. It was... 727712-80W00 (w/antenna) The rubber molding and the chrome trim used in or on it is the same until 05 '85 when both were cosmetically changed. Note: either of the rubber and the chrome trim won't swap with those after 05 '85 and have to be used as a set. I think it safe to say any windshield that is clear, tinted or has an antenna in it will interchange after 06 '83. So yes an '84 windshield should fit an '85 or the other way around. An '85 rubber molding will also work on the '84 glass, but you will likely need the '85 chrome trim that is matched to it.. Quote Link to comment
