Sr20de Alternator Issue
Friscolada
I was finishing my swap for sr20de (s13), and last thing was check that alternator works. So i ended up finding that my fuse was blown, and i fixed everything checked.
Now when i crank the car over, it idles for a bit and then dies. So i went and disconnected Alt and it was running fine.
Here is my wiring set up for alt: Black - ground, Thick White- charge wire to Battery with inline fuse (80), Thin White wire- to 12v with inline fuse (20). I didn't connect charge light wire (white and red).
Any ideas why will this be an issue, im thinking of pulling that alternator off and getting it tested. I do how ever know that the alternator charges, my voltage jumps to 14.5 when it kicks in.
  • Replies 0
