iwayman Posted June 8, 2012 Author Report Share Posted June 8, 2012 Gonna try flipping the TDC. The guy who rebuilt my engine told me it was at it but I'll check tomorrow. Been adjusting and fiddling with the dizzy all afternoon. Correct me if i'm wrong but I dont think timing is adjustable in the L28et. I thought timing was determined by the ecu. Quote Link to comment
ggzilla Posted June 8, 2012 Report Share Posted June 8, 2012 Firing order of a straight-six is 1-5-3-6-2-4. On an L-series engine it is anti-clockwise. L28ET, i think you still have to set the initial timing to 0. Then the ECU varies it once the engine is running. Your manual should say. Quote Link to comment
iwayman Posted June 8, 2012 Author Report Share Posted June 8, 2012 Ya i've got the firing order set up and I've played around with the dizzy enough to have definitively been close to 0. We'll see if its just the wrong tdc tomorrow when I get a chance to test. Tomorrow man can do anything! Quote Link to comment
fo0manchu Posted June 8, 2012 Report Share Posted June 8, 2012 almost there, sooo close! Quote Link to comment
iwayman Posted June 8, 2012 Author Report Share Posted June 8, 2012 Had a friend come over and we redid the timing w/ TDC. It runs! Fucking crazy loud with just a downpipe. Gonna get exhaust built monday and I'll be on the street next week. Just in time for the local Z car meet :) For some reason it runs rough and it dies pretty often between downshifts. I set my intial BTDC to about 20. I also tried nearly 0 and it didnt run any better. Any ideas? Is there such a thing as getting too much flow through the exhaust? All I had hooked up was about 3.5' of 3" mandrel bent downpipe... Quote Link to comment
iwayman Posted June 8, 2012 Author Report Share Posted June 8, 2012 Ran out of gas on a test run >.< got bored waiting so I took some pics. Heres one. Quote Link to comment
fo0manchu Posted June 9, 2012 Report Share Posted June 9, 2012 Looking good! congrats on getting it running! Have you checked for vacuum leaks? Quote Link to comment
ArchetypeDatsun Posted June 9, 2012 Report Share Posted June 9, 2012 Had a friend come over and we redid the timing w/ TDC. It runs! Fucking crazy loud with just a downpipe. Gonna get exhaust built monday and I'll be on the street next week. Just in time for the local Z car meet :) For some reason it runs rough and it dies pretty often between downshifts. I set my intial BTDC to about 20. I also tried nearly 0 and it didnt run any better. Any ideas? Is there such a thing as getting too much flow through the exhaust? All I had hooked up was about 3.5' of 3" mandrel bent downpipe... Mine died when I had just the downpipe. Where are you getting the exhaust done I been wanting go 3" all the way and I got quoted $800-1000 which was way too much for me. If you look up Big Phil on youtube he has a 280z with a L28ET swap he had a holset diesel turbo with 4" exhaust. Your looks stock, so I would keep it 3", my car still runs funny so I have figure out what's going on with it. Quote Link to comment
ggzilla Posted June 9, 2012 Report Share Posted June 9, 2012 20 BTDC as risking a burnt piston when you rev the engine up under load. Set it to the stock spec to start with. If it doesn't idle well at the stock spec, it's not the timing that causing it to idle rough. Quote Link to comment
iwayman Posted June 9, 2012 Author Report Share Posted June 9, 2012 Timing wise I used this thread, 1st reply, because Im not sure what the timing is actually supposed to be, I didnt see it in my book as I skimmed through lol http://www.zcar.com/70-83_tech_discussion_forum/1982_280zx_turbo_timing_880559.0.html And I havent gotten a quote because I assumed my exhaust would cost about 2-300$ but I'm taking the z to Quality muffler and brake (the one right across the street from the lithia body and paint). I already have a 24" 3" glass pack and a 3 into 4" straight through ricer can plus I built my own downpipe so all I need the guy to do is stick everything together with some 3" mandrel. I dont have any vacuum leaks that I know of and I boosted to about 8psi max, since I adjusted both the BOV and the wastegate to their lowest settings. I'm not sure how the air regulator works but I'm not using it right now. Does it activate as the engine drops to idle? I thought it just opened for cold starts but could it be a reason for killing the engine? I've also got an aluminum radiator on order since I found out that my stock one has a little crack in it so it leaks a little coolant and I was also running about 225 degrees (according to my stock temp gauge if thats remotely accurate) hopefully I'll get it and install it before the local z car show next weekend :D Quote Link to comment
ggzilla Posted June 9, 2012 Report Share Posted June 9, 2012 Vaccum leaks are usually not evident by sound or sight. But because it doesn't idle correctly. You have to inspect the hoses and diaphragms looking for them. The air regulator is necessary to idle correctly. It sets the idle. Quote Link to comment
fo0manchu Posted June 9, 2012 Report Share Posted June 9, 2012 is your bov recirculated? If not, that can cause your car to run rich. Also, cheap bov's sometimes leak at the diaphram letting air out. They seal great when under boost when the manifold pressure helps it close. Basically that would be a big vacuum leak. I know this by experience! Quote Link to comment
iwayman Posted June 9, 2012 Author Report Share Posted June 9, 2012 well I set up my air regulator. Got some fancy brass couplers for fun. Hoping that will eliminate the engine dieing during downshifts. And ya I bought a cheap bov off ebay lol Quote Link to comment
iwayman Posted June 12, 2012 Author Report Share Posted June 12, 2012 First run with the car: got the exhaust built today but no video right now. How can I change the title of this thread? Quote Link to comment
ggzilla Posted June 12, 2012 Report Share Posted June 12, 2012 How can I change the title of this thread?Go to the first post and click Edit. Then click "Full Editor". You can change the title. Quote Link to comment
iwayman Posted June 12, 2012 Author Report Share Posted June 12, 2012 full 3" with my glasspack and ricer can. Even without the silencer the new exhaust is quieter than my old exhaust, a straight 2.5" with headers and only one muffler. Quote Link to comment
ArchetypeDatsun Posted June 12, 2012 Report Share Posted June 12, 2012 I remember when i ran mine to the shop without an exhaust. I don't know if you already know this but turning off a turbocharged engine like that is bad for the turbo you should wait up to 1-3 min depending how hard you ran the car. Nice video indeed good to see it running. Quote Link to comment
iwayman Posted June 12, 2012 Author Report Share Posted June 12, 2012 I don't know if you already know this but turning off a turbocharged engine like that is bad for the turbo you should wait up to 1-3 min depending how hard you ran the car. Ya I heard it cooks the oil in the turbo or something like that. I love how quiet it is now! Quote Link to comment
ArchetypeDatsun Posted June 12, 2012 Report Share Posted June 12, 2012 Yep, you can always buy a turbo timer I need one lulz. How much did your exhaust cost you? Quote Link to comment
DAT510 Posted June 12, 2012 Report Share Posted June 12, 2012 Mmmmmm turbos :lol: New video! Noaw! :D Quote Link to comment
iwayman Posted June 12, 2012 Author Report Share Posted June 12, 2012 I got the muffler for 40, glasspack for 25, and everything installed for 300. I'll post a couple videos of the exhaust, before and after, in a little while. It took 6 hours to upload that last video! >.< I'm hoping my z will be running well enough for the local z show this weekend, got an aluminum radiator on order to help combat overheating lol may have to run electric fans on the front and build a shroud for the inner fan too. It jumps all the way up to 250F within 10 minutes... Quote Link to comment
ArchetypeDatsun Posted June 12, 2012 Report Share Posted June 12, 2012 I got the muffler for 40, glasspack for 25, and everything installed for 300. I'll post a couple videos of the exhaust, before and after, in a little while. It took 6 hours to upload that last video! >.< I'm hoping my z will be running well enough for the local z show this weekend, got an aluminum radiator on order to help combat overheating lol may have to run electric fans on the front and build a shroud for the inner fan too. It jumps all the way up to 250F within 10 minutes... Damn what place did you get it installed at quality muffler got an expensive quote I wanted to try J&L muffler cause I want a 3" mandrel bend downpipe and 3" exhaust and I would supply the muffler. The one I have on now is like falling off lulz and there like no where to put the bracket. Damn six hours what do have dial up? Mine takes like a minute or less depending on the size. I'm anxious to see your Z. Quote Link to comment
iwayman Posted June 13, 2012 Author Report Share Posted June 13, 2012 Not sure why my internet is so slow. I'm uploading the videos to youtube first though. I went to Quality muffler and brakes, i think thats the name. Either way, it's the place across the street from Lithia body and paint. He does some solid work, my exhaust looks very nice, and my friend took his 190e in with his own muffler for a good result too, I think his was cheaper because it was 2.5" crush bend tho. The guy doesnt have a mandrel bender but he does have mandrel bent 3" piping, I bought some from him for my downpipe and he used it for the rest of my exhaust. And i'm excited to show off my car lol just gotta do something about it overheating so much... I think thats why its not running well. Here's the first video, my NA exhaust. The revving is rly short because I saw the smoke go past my door and cut it short. The other video still has 45 minutes... for a 30 second video or something like that Quote Link to comment
ArchetypeDatsun Posted June 13, 2012 Report Share Posted June 13, 2012 What Internet provider do you have? Quality Muffler is where I called to get a quote and the person told me $800-1000 for a 3" exhaust but unless they quoted me the wrong car I'll have to go in person next time I guess. Quote Link to comment
