510 Hard Brake line
Im looking for the driverside hard brake line/tube since mine broke, if anyone has one lmk or if someone can make one that would be better thanks
  • Replies 9
Which one ? Can you give more detail ? I have some - but let me which one. Where in CA
Driver's side. Not the one that goes to the right, and not the one that goes to the rear.
Driverside front. im located in Murrieta/Temecula near Riverside let me know if you have one thanks
Take it off and roughly measure the length. Take it to an auto parts house and get a pre made one matching your length. Note there are different styles of flair on the ends. Use yours to check the thread pitch matches. Take home and bend into the same shape. Wrap around something like a baseball bat to prevent kinking. Tape the fitting out near the ends so they don't slide down and get behind a bend and you can't slide them out again. You should be able to fix this for $5.
Follow Datzenmike's recomendation and get the tubing from the parts store.
The nut on the 510 hard lines has an M10x1.0 thread. Tubing is 4.75mm or 3/16". The nut size on OE is 10mm, likely the parts store tubing nut will be 11mm, but that is not a problem.
You want the standard double flare tubing, not the bubble flare (those are for European cars mostly).
Correct double flare on left
Wrong bubble flare on right
This is one of the things all old Datsun owners must be aware of. Many times you can't just go out and buy the part you need. I doubt very much that Nissan would still have this part in stock even if you had the money to throw at it. So the owner is left with having to find something that will work in it's place or even make one himself. If you want to keep your car on the road you will just have to get used to scrounging and even making your own parts. Even this can be fun and enjoyable. There is nothing like the feeling you get when you make something with your own hands that serves a purpose.
Be sure to get a brake line wrench for those fittings. It will prevent stripping the fittings.
brake line wrench
proper brake line wrench, do it right
