Sign in to follow this
Jayden71
My shaft broke my asain tranny!!
So I was on my way to Idaho today to play Datto with Chet and Wide when I felt a horrible vibration and then cab started filling up with blue smoke!! :o I rolled down all windows (2) and pulled off at next exit. A horrible noise was coming from tranny while I was slowing down. I checked it out and found this
Tranny was literally falling apart, rear seal gone and aluminum chunks all over the place!. So I turned around and headed back home. At 45mph a bad vibration could be felt so I limped her home at 40 and did just fine.
Got home and in 2 hours had tranny pulled to get a better look.
Front ujoint right behind flange gave out <_< and took 4 spd asain with it!
This actually happened for a good reason!! Better now than on the way to cAndy. Last year clutch this year tranny!!
I have time to put this baby in before caNdy still
dogleg from early 200sx :D .
So this will actually be a tranny swap thread. I have a 1 piece driveline that I want to use. I have done prelimanary measurements and it looks like it will need to be lengthened aboot 2-3 inches. (Thats what my wife always tells me too!!)
I am going to put dogleg in then measure to have tranny mount cut and welded back together. Then I will measure for driveline as well. If I can't get driveline done in time I may go with a 620 front half. I just really want to get rid of carrier bearing!
I will be using fork and throwout bearing and collar from the original 521 tranny.
I hope this will help some of the 521 guys that are looking to do this swap :cool: .
I prolly won't put dogleg in untill next weekend. (Hate my job sometimes most of the time)
Share this post
Link to post
so your not coming over lol
sorry about the trany
:fu:
....and you thought I was bullshitting you!! :hyper:
Share this post
Link to post
Guest 510kamikazifreak
Dang that must have been some driveline vibration :blink: ..
Good thing it happened close to home..
Share this post
Link to post
I feel sorry aboot the tranny, she will never be the same. Hey we can't get it together. We can take my truck to CaNdY. Ollz
Share this post
Link to post
Yeah there was some porn star strength vibrator action. Made it 50 miles before turnin round
Meh....521 tranny, moar scrap moneyzz!!!!
My truck MUST GO!!!
Share this post
Link to post
I'm thinking mine might have to go too pllz
Share this post
Link to post
Just use shims for sloppy trannys, trust me.
Share this post
Link to post
what aboot leaky onez??
Share this post
Link to post
Mike what would one do aboot a tranny that screams in 5th and neutral, when the clutch is not pressed in.
Share this post
Link to post
Hey !!! Start your own thread! If your tranny is screaming you are doing it right
Share this post
Link to post
Put a new seal around your shaft.
Share this post
Link to post
Check the oil level. If desperate, you could fill with 140W gear oil to maybe quiet it but only until you can get it out and fixed or replaced.
Share this post
Link to post
Title...of this said porn star vibration action
Vibed till it cracked?
Share this post
Link to post
Over vibed crack action :w00t:
Share this post
Link to post
:rofl: :w00t:
all outta likes still :confused:
Share this post
Link to post
Look at the bright side.... at least the tranny broke and your shaft didn't snap off inside. I fuckin' hate that.
Share this post
Link to post
wow man... that asian tranny wasnt up to the task...
this happened to me in my isuzu once... front ujoint goes out, and bam, you need a new tranny!
too bad you couldnt come and play... :lol:
Share this post
Link to post
shaft extraction can be costly and painful
Share this post
Link to post
Old thread res erection time.
So last May, I was ready to do the 5spd thing. Found a 620 parts truck. Was going to use the splined front half of driveline to replace my flanged 521 front half. Yeah that didn't work. Someone long ago had put a complete 521 drivetrain into said 620!!! :confused:  :o  :mad: . FUUUUUUU......So i did the 4spd thing again. However, Asain tranny swap is going to have a happy ending!! Finally got the correct shaft and me and Chet are playin trannies tomorrow :thumbup:  :thumbup: :thumbup:  :thumbup:  :thumbup:  :thumbup: . If all goes well I will have dogleg in my 521 by tomorrow afternoon. :w00t:
Share this post
Link to post
I much prefer Aisin Warner transmissions to the JATCO Ford based models. Looks like I want Nissan engines and Toyota transmissions.
Share this post
Link to post
So i was lookin around for the correct shifter and wound up sticking my black rod into my asain tranny
Share this post
Link to post
AWWWWW YEAH!!!!! Finally got dogleg all buttoned up and bolted in 521!!!!! I love it!!! Already put 150 miles on it today, no problems!
1st gear is a little tall for my L16 but waaay better than the original 4spd. I gained about 10mph. Since my truck has 488s in it I now turn about 3550 at 65mph. I am very happy with that for now. Farmer Joe has a 437 set for me to throw in some nice summer evening.
Puttin it in was a little more troublesome than first thought.. Tranny is same length as shortty 4spd but is a little wider in just the wrong place so, we had to take the pressure plate off to get it up in there.
Measured the mount to have it cut down and that didn't turn out as we had planned. We got a 1/4" thick piece of angle, took the mount and ground it down another inch or so and had mount welded to angle then bolted to cross member then bolted tranny down. Was able to stay away from any cutting on the truck.
Oh yeah, and I am still running the original flange driveline! :sneaky:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
