MPFI on a z24
mobilejoe
that's what i had. two sets of injectors, one mass air sensor, and it would all ways idle rough or just shut off when it felt like it. that's within a 3 month time table (just bought this truck)
and then i find the wire harness problems and switched to a 1992 harness because that's what i could find. and that's why i'm doing a mpfi on the z24
but at the point i have gone back though the system.
useing the fsm i have tested all the sensors,voltage,ohms etc etc. it all reads good!
i have used a matching 240sx ecu and sensors and maf,throttle body and I get the same thing
I even put a second inline efi fuel pump just to try it and that did not help. I have 39 psi at idle
pulled the injectors and had them checked and there fine.
I even pulled the intake back off to make sure i did not screw anything up, it was fine
so that this point i'm left scratching my head wondering how to fix this thing
  • Replies 68
what about when i used the 240 stuff I mean i used even the temp sensors, ma,f throttlebody, tps sensor, o2, computer,harness, etc etc
and it made to difference i had the same lopey idle and really rich
that was a matched setup from the same car
What I'm thinking is it has to be something in the motor. The stock efi system had a rough idle and sometimes go rich
I'm just wondering if swapping the efi out to the new system made it show up more?
At this point i'm thinking time for a motor swap
ka24
or
l20 ???
I guess it will come down to what I can find complete
yea I wish my local yards don't have a complete setup (they pulled motors and cut the harness)
The one yard wants 900 for a bare ka24e !!
but the really good yard (i like them alot they are great to deal with)
This is what he has:
93 pathfinder vg30e
98 pathfinder vg33e (not complete needs alt,ps, brackets,ect)
94 maxima vg30e
85 300zx with a bad motor but complete car
The only 2wd oil pan/pickup he has is from a 86 3.0 d21, will that fit the 93,98,maxima??
what would your pick be?
and will the vg33 run with the vg30 computer,sensors etc...
thanks
  • 1 month later...
The system works my problem was a blown headgasket,cracked block, and a warped head. The truck had to much rust and needed to much money and time. But yes it works. Also there is nistune which will allow you to fine tune it out. This will give you alot of info:
http://www.infamousnissan.com/forum/showthread.php?t=21987&highlight=z24+swap
  • 6 years later...
Last visited just over 4 years ago. Mibilejoe... he gooowne
