mobilejoe Posted May 19, 2012 Report Share Posted May 19, 2012 I have a 1987 nissan hardbody with a Z24I (8 plug)motor. My throttle body is dieing (mass air meter again). So I what to switch over to multi port fuel injection. I have found a 1983 200sx (2.2) intake round ports instead of square, but it all lines up and bolts on. I also have 4 fuel injectors, A 1996 altima 2.4 throttle body with mass air flow meter. (bolts right up) I will have to have the opening in the intake matched to the throttle body. I know that I will have to do some wiring, which is not a problem for me. Here are my questions: What computer should I use? I have a ka24e truck computer, Also I was thinking about a 1992 stanza (also ka24e), It wires up the same only it has fan controls(would be nice) But If I use the ka24e computer how would I get the second set of plugs to work? Also would it be better to keep or get rid of the egr system? I live in fl so no emissions. B) Any and all ideas/questions would be great? Thanks Quote Link to comment
Spades Posted May 19, 2012 Report Share Posted May 19, 2012 EGR will not hurt anything, so if it is working don't mess with it. Honestly, if I was going to attempt to convert a TBI vehicle to MPFI, I would use stand alone engine management unless it was a direct swap. As far as your 8 plug concern, I had read that Jacobs makes programmable ignition system for the Naps Z 8 plug engines...there may be a way to use your distributor with a MPFI set up, especially if you are using your own engine management. But in the end, is it really worth it? Power and mileage gains from TBI to MPFI on this motor would be minimal, and most likely negated by your mismatched intake ports. Unless the datsun gurus here can give you a magical set up that will let you use junkyard parts, I would say it is time for an engine swap or a new Nissan MAF and/or troubleshooting what is burning them out. 1 Quote Link to comment
mobilejoe Posted May 19, 2012 Author Report Share Posted May 19, 2012 Food for thought. At some point I will be building a napz motor and doing a turbo that's the long term goal. I kknow a ka24 motor setup would be a bolt in and easier swap blah blah blah But I would like to stay with a napz style motor. :sleep: I am getting a z22 lower block and that will be the base for my motor. Any how before I start to rebuild motor I need funds first. Also when I do the new motor I would what it to be mpfi. So seeing that I have this problem with the throttle body I figure lets get the mpfi system done and tested (yes when I go turbo I will change computer and fuel injectors) Quote Link to comment
mobilejoe Posted May 19, 2012 Author Report Share Posted May 19, 2012 Dumb question Why can't a person take a ka24e ecu and wire both coils to it? Or Why not use both computers ka24 and the old one Ka24 for the efi old one for the coils Quote Link to comment
datzenmike Posted May 19, 2012 Report Share Posted May 19, 2012 Sealick has done this with an early 200sx EFI onto a Z24. The AFM needs adjusting for the larger displacement. Another guy I know has used the 200sx EFI manifold but swapped KA sensors/injectors and ECU over to it. Both the KA and the 8 plug Z24i us a crank angle sensor so firing 8 plugs isn't a problem. 1 Quote Link to comment
mobilejoe Posted May 19, 2012 Author Report Share Posted May 19, 2012 sweet Here's my parts list: 96 altima with a ka24e motor 1) throttle body with throttle sensor (had to change the throttle cable bracket used 91 sentra bracket and spring) 2) mass air flow sensor 93 pathfinder 1)air box (the 2.4 mass air all most bolts on you just have to elongate the holes in the air box 10 minute job) 83 200sx 1) intake 2) fuel rail 3) fuel regulator 89 240sx 1) 4 fuel injectors with brackets 92 stanza 1) ecu OR 92 d21 1) ecu ecu wire/plug I think i will block off the egr system.and remove the rest of the emission stuff This is what I'm think about using for the idle air control, I can mount it out of the way. http://www.ebay.com/itm/Volvo-850-960-S70-V70-C70-S90-Idle-Air-Control-Valve-IAVC-93-00-BOSCH-0280140542-/261027050600?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc66cb468&vxp=mtr Quote Link to comment
HRH Posted May 19, 2012 Report Share Posted May 19, 2012 Easiest way to fix it is make an adapter to run a 32/36 or 38/38 weber. Just ignore the EFI. Another option is to get a single cam KA head and put that on. http://community.ratsun.net/topic/25243-ka-z24-build-compression-questions-done Quote Link to comment
datzenmike Posted May 20, 2012 Report Share Posted May 20, 2012 A KA24E head will drop the Z24 compression to 7.614 Quote Link to comment
mobilejoe Posted May 20, 2012 Author Report Share Posted May 20, 2012 ok so no ka24 head I have a long term goal, I know that ka24 motors are newer, cheaper, and a easy swap... But I like the look of the dual plugs and naps motors. At some point I'm thinking of building a Frankenstein z22 motor or z24 but I do want mpfi So with my throttlebody screwing up again (when cold will not idle, when hot it will die when ever it feels like it or you shift into 3rd to fast) So thats why I'm switching I did take the intake and had it matched to the new throttle body I plan on ordering gaskets and parts latter today, I think I have most of what I need. Also is there a good place to buy egr block plate. this is a link to a idle air valve, think it will work or do you have a better idea (i like it does not bolt to the intake I don't have a spot on my intake) http://www.ebay.com/itm/VOLVO-240-740-940-IDLE-AIR-CONTROL-VALVE-0-280-140-516-IAC-MOTOR-SAAB-/280882045429?pt=Motors_Car_Truck_Parts_Accessories&hash=item4165dfe1f5&vxp=mtr Thank you for all the info Quote Link to comment
datzenmike Posted May 20, 2012 Report Share Posted May 20, 2012 Just disconnect the vacuum line to the EGR and it will stop working. If you have to, remove the SS line to the exhaust manifold and replace with a metric thread pipe plug. Or just crush the open end of the pipe with vice grips and fold over to seal it. 1 Quote Link to comment
mobilejoe Posted May 20, 2012 Author Report Share Posted May 20, 2012 I had to soak the intake for two days just to get all the gunk out of it!!! I'm guessing it's from the egr system. I need a fuel pressor regulator the one from a 83 z200 is $80.00 (ouch) Any better ideas aftermarket?? oem??? Quote Link to comment
mobilejoe Posted May 21, 2012 Author Report Share Posted May 21, 2012 Found a 92 stanza ecu and a idle air control form a vw jetta Also ordered all the gaskets will be in on Thursday. Will post more latter Quote Link to comment
mobilejoe Posted May 27, 2012 Author Report Share Posted May 27, 2012 Here's a link to a thread it has a few pics Any ideas as to how to make a air tube from the throttle body to the air box on the driver side (using a stock pathfinder box with a atlima mass air) http://www.infamousnissan.com/forum/showthread.php?t=21578 Quote Link to comment
Sealik Posted May 27, 2012 Report Share Posted May 27, 2012 I'm using a VG throttle body and the stock 200SX air flow meter..... ran a 3" pipe between the 2 Quote Link to comment
mobilejoe Posted May 27, 2012 Author Report Share Posted May 27, 2012 is the pipe metal or pvc ? Quote Link to comment
mobilejoe Posted May 27, 2012 Author Report Share Posted May 27, 2012 heres some more pics http://www.infamousnissan.com/forum/showthread.php?p=279282#post279282 Quote Link to comment
Sealik Posted May 27, 2012 Report Share Posted May 27, 2012 is the pipe metal or pvc ? metal Quote Link to comment
mobilejoe Posted May 28, 2012 Author Report Share Posted May 28, 2012 Hit my first major problem. I found several wires that were chewed up (by mice??) and some that were green so I had to pull alot of wire out So now I need to build a new engine harness, all the way back to the ecu and then tie it back in to the good half of the truck harness... I'm good, but yea this is a big problem and I know that the local junk yards cut the harness when they pull the motors. I'll go look tuesday and see, I know that there is a 200sx (1.6 front wheel drive) complete. ????? Quote Link to comment
mobilejoe Posted June 1, 2012 Author Report Share Posted June 1, 2012 Ok I'm back on track I just found a good harness from a 92 d21. The best part is it is for a ka24e motor so I just need to extend some wires. You got to love "little" surprises Quote Link to comment
mobilejoe Posted June 1, 2012 Author Report Share Posted June 1, 2012 does any one know about temp sensors?? The stock nissan one is to small to screw into my intake. I don't have the room for a adapter. so why questions is A ford temp sensor screws in, but would it work with the nissan computer? Quote Link to comment
mobilejoe Posted June 6, 2012 Author Report Share Posted June 6, 2012 question I can not get the injectors to fire. I have 12+ at the common wire for all the injectors, but I don't have a ground signal from the computer. I have tried 2 computers I have tested the injectors by hooking them to a battery and they work. what am i doing wrong and or missing :sneaky: :w00t: also when I hookup the injectors into the harness i get a 12+ reading on both wires? is this because of the coil inside the injector? Quote Link to comment
ggzilla Posted June 6, 2012 Report Share Posted June 6, 2012 does any one know about temp sensors?? yes, we know about temp sensors. But whether a Ford unit is compatible is unknown. You are talking about the air temp sensor? You could get the factory service manuals for both and compare specifications. These FSM are usually available at larger public libraries. Don't use an adapter, it needs to go in where the air is flowing, rather than in a pocket of an adapter. Some ideas: * Find a Nissan sensor that is larger diameter (e.g. different model) -- if one exists * Drill a new hole for the smaller sensor, then and tap it for the correct thread * Use JB-weld to make the hole smaller, then tap it for the smaller thread Quote Link to comment
mobilejoe Posted June 6, 2012 Author Report Share Posted June 6, 2012 thank you ggzilla but i was talking about the water temp. I found a port on the bottom of the intake that the sensor screwed in (after i remove the plug) I went to the junk yard and got a 3rd computer plugged it in without the injector and I still do not have the injector signal coming from the computer so that means that i am overlooking something. any ideas/help thanks Quote Link to comment
ggzilla Posted June 6, 2012 Report Share Posted June 6, 2012 Buy a 4th computer just to be sure. Or, find out what the problem is and then fix it. Do you have *all* the parts for the EFI system? Do they match? Do you have the dropping resistor for the injectors, or does the particular system not use that? Quote Link to comment
mobilejoe Posted June 6, 2012 Author Report Share Posted June 6, 2012 i have the following: motor is a z24i with a 83 z22 intake (multi port fuel injector system) ka24e stuff: computer wire harness mass air flow sensor throttle body water temp sensor 83 280 fuel injectors fuel pressure regulator using the stock z24i dizzy with the crank angle sensor I do not have any emissions stuff. also I have spark from both coils I checked for power at pin 46 (per fsm) and it's there I know the dizzy worked on the old efi setup that's about all i can think of at this moment Quote Link to comment
