Sierra Posted May 15, 2012 Report Share Posted May 15, 2012 I purchased a new EGR Valve on Rockauto for my 1978 B210. The valve is made by Standard Motor Products (Part# EGV329). The orifice where the valve pin comes out needs a specific washer that makes the hole big or small based on the make and model of the car you are going to install the EGR Valve. The Valve comes with a one page instructions/specifications that expalins what washer (number stamp on washer) to use based on the O.E. number of the original EGR Valve. Since the old valve was a after market EGR valve I don't have the O.E. number to assigned the specific size of the washer. Anybody out there knows that the hell I am talking about? Anybody with a parts catalog that can get me the O.E. number for the EGR valve. Quote Link to comment
ggzilla Posted May 15, 2012 Report Share Posted May 15, 2012 1978 uses the largest size Quote Link to comment
Sierra Posted May 15, 2012 Author Report Share Posted May 15, 2012 Sweet! thanks for the response. It was driving me crazy. Out of curiosity. What would happen if I use smaller size orifices washers? Quote Link to comment
ggzilla Posted May 15, 2012 Report Share Posted May 15, 2012 Then the EGR wouldn't work as well. It would only be as good as a 1976 B210. Cough, cough Quote Link to comment
Sierra Posted May 15, 2012 Author Report Share Posted May 15, 2012 Thanks again for your speedy response. Quote Link to comment
ggzilla Posted May 15, 2012 Report Share Posted May 15, 2012 Nissan used about a dozen EGR valves on the B210, each slightly different from the previous. Standard Motor Products decided to make ONE valve instead, but with different sized inserts. Look on your underhood sticker, to see if it meets California, Federal, or Canada emissions. Then was it a factory 5-speed car (65HP) or not (80HP) will be on the ID plate on the firewall. Here are the five OEM part numbers for 1978 B210 EGR Valve 14710-H7700 FED 4-speed 14710-H7710 FED AT 14710-H7760 FED 5-speed 14710-H7760 CAL MT (4 or 5-speed) 14710-H7770 CAL AT 14710-U9400 CAN Quote Link to comment
Sierra Posted May 15, 2012 Author Report Share Posted May 15, 2012 Thanks ggzilla I will check the underhood sticker. I am pretty sure that meets California emissions. Since it was originally purchased in California and I am in California. Su just to make sure. The B210 is an Automatic so the OEM part number for the EGR Valve is 14710-H7770 Quote Link to comment
ggzilla Posted May 15, 2012 Report Share Posted May 15, 2012 That sounds right to me. Quote Link to comment
