510 gas struts for hood
dgi
I've had the parts for a while to put gas struts on my hood. But, I've lost the article showing the mounting points (dime quarterly maybe?)
Anybody got a picture or a copy of the original article?
Thanks,
dgi
  • Replies 4
One of the kits I had came with a diagram, which was essentially useless. Heck, even half of the hardware was useless. Your best bet is trial-and-error. That's what I ended up doing, and it's worked out fine.
@yellowdatsun... thanks for the picture. That will help me visualize how I will have to mount mine. Mine are much shorter than the ones in your picture.
This is my order from McMaster-Carr. Should have ordered nuts and lock washers for the ball studs while I was at it.
Substantially shorter than the ones picture above. I believe these are the items listed in the original Dime Quarterly write up that I've lost.
Line Description Ordered Shipped Balance Unit Total
1 9416K144 Gas Spring with Threaded Ends, 90 Force, 5.51" Extended Length, 1.97" Stroke 2 Each 2 11.61 23.22
2 9416K74 10 mm Steel Ball Socket for M6 Thread, Gas Spring with Threaded Ends 4 1.98 7.92
3 9512K73 Ball Mounting Hardware, 10 mm Zinc-Plated-Steel Ball Stud with 5/16"-18 Male Thread Each 4 1.03 4.12 Merchandise 35.26 Shipping 5.72 Total $40.98
