Zeusimo Posted April 3, 2012 Report Share Posted April 3, 2012 Atleast You Lowered It... Quote Link to comment
Meltor Posted April 3, 2012 Author Report Share Posted April 3, 2012 Atleast You Lowered It... Lowered? its stock height! 235/75/r15 Quote Link to comment
poopypants720 Posted April 3, 2012 Report Share Posted April 3, 2012 What caused you to get stuck in the first place? clearance/traction or sucking up some water? Quote Link to comment
Skulptr Posted April 3, 2012 Report Share Posted April 3, 2012 Your front end is sagging. My single cab at height ran quite a bit higher Quote Link to comment
Meltor Posted April 4, 2012 Author Report Share Posted April 4, 2012 What caused you to get stuck in the first place? clearance/traction or sucking up some water? the ruts in that hole were far to deep. i was highcentered. Quote Link to comment
poopypants720 Posted April 4, 2012 Report Share Posted April 4, 2012 the ruts in that hole were far to deep. i was highcentered. you know what that means??? Time for a suspension lift and bigger tires! That will help out some. Quote Link to comment
Meltor Posted April 4, 2012 Author Report Share Posted April 4, 2012 you know what that means??? Time for a suspension lift and bigger tires! That will help out some. i have so much more to get done with this thing. tires are on the list. among other things. soon enough as money allows Quote Link to comment
poor-mans-720 Posted April 7, 2012 Report Share Posted April 7, 2012 make you a killer deal on 31's!!! frankley cause i need the money to get 33's... :) located down near tacoma Quote Link to comment
