Nissan_Boy85 146 Posted March 18, 2012 Report Share Posted March 18, 2012 Ok, I know I've seen it before, not sure where and I've spent too much time scowering Ratsun and Google for it. Does anyone know or have a link to some dimensions for a "DIY Timing Chain Wedge" for a Z24? The head gasket decided to go buh-bye and I need to get it done before next weekend. Thanks in advance!! Quote Link to post
DAT510 856 Posted March 18, 2012 Report Share Posted March 18, 2012 Just a shaved down 2x4 or any piece of wood in a wedge shape. I think Hainz has one in one of his videos Quote Link to post
datzenmike 38,406 Posted March 18, 2012 Report Share Posted March 18, 2012 Before locking timing chain, loosen the cam sprocket bolt first, then set TDC. Motor MUST NOT MOVE once locked or chain will loosen. Block the wheels and place in neutral so jostling the body won't bump the motor over. Make a wedge from a piece of wood. 1/2" wide and 6 1/2" long and tapering from 1 3/4" at one end down to 1 1/4". Drill a hole in the wide end and thread some rope through it so you can pull it out easier. Hammer down firmly between the chains below the cam sprocket You can buy them but time and gas... just make one. I've heard of stuffing a folded piece of garden hose down between the tension and slack chains. All you have to do is support between the chains to prevent the tensioner from pushing out when the cam sprocket is removed and there is any slack. THIS... must be avoided... 1 Quote Link to post
Guest 510kamikazifreak Posted March 18, 2012 Report Share Posted March 18, 2012 Use Mikes measurements and you will be good to go. I made one about 20 yrs ago and it has done at least 40-50 head gasket installs Quote Link to post
Laecaon 1,434 Posted March 18, 2012 Report Share Posted March 18, 2012 I use a hammer handle. Fit perfectly down. Though it is loose. I tried hammering a block of wood down, but it got stuck, so dont hammer too much. I just use it to keep the tensioner from pushing out, then when you take the cam gear off, just make sure to fold the chain over appropriately to avoid it falling down. Worked for me 4 out of 4 times I have done it. Quote Link to post
lil89ram50 26 Posted May 5, 2012 Report Share Posted May 5, 2012 timing cover must be removed if tensioner falls apart? can tensioner be put back together? just had this happen tonight doing a cam. wood didnt holt tight enough and popped upwards :( Quote Link to post
Jayden71 1,960 Posted May 5, 2012 Report Share Posted May 5, 2012 timing cover must be removed if tensioner falls apart? can tensioner be put back together? just had this happen tonight doing a cam. wood didnt holt tight enough and popped upwards :( Yes tensioner can be put back together rather easily. remove timing cover and fix. You gotta jam wood down in there between the guides to keep it from falling out. drill hole throught he top of it and attatch a piece of rope to get it back out when done Quote Link to post
lil89ram50 26 Posted May 5, 2012 Report Share Posted May 5, 2012 yea i made a wedge. just didnt jam it in far enough. got the cover off now, Quote Link to post
banzai510(hainz) 4,715 Posted May 5, 2012 Report Share Posted May 5, 2012 just buy the correct wedge. I dont know why people dont have these for there motors you will use it one day. 10$ is alot ezer than pulling a front cover after the fact(esp when you didnt loosen the crank pulley bolt) amazon has the tool. I had bought 10 of them from Schucks back in the day for 5$ apc and gave them all away. when you push it down you can feel it slip past the tensioner and lock on. and has a nice pull wire to pull it back out. 1 Quote Link to post
Dawa 353 Posted May 16, 2013 Report Share Posted May 16, 2013 when i removed my head a few months ago i was looking for the dimensions.. then realized i didnt have any way to cut wood at home. i came across another guy who talked about stuffing a hose (garden hose or similar) down between the chain. i did that and it worked awesome Quote Link to post
izzo 1,602 Posted May 16, 2013 Report Share Posted May 16, 2013 Don't cut the timing chain wedge to the dimensions above. It doesn't fit. I tried it.... Ill have to measure mine when I get home. 1.5 inch on top, 1.25" on bottom IIRC.... It fit snug and perfect all the way down. I will have to measure length. 2 Quote Link to post
bmacster 7 Posted May 17, 2013 Report Share Posted May 17, 2013 Don't cut the timing chain wedge to the dimensions above. It doesn't fit. I tried it.... Ill have to measure mine when I get home. 1.5 inch on top, 1.25" on bottom IIRC.... It fit snug and perfect all the way down. I will have to measure length. That would explain why mine didn't work as it should. Would love to see the new specs on the wedge so I can make some! Quote Link to post
mklotz70 3,211 Posted May 17, 2013 Report Share Posted May 17, 2013 I know I've put this up somewhere before, but I don't know where. So, I just added this page/file to my site. The pdf should print out at the correct size....or at least really close. http://www.bluehandsinc.com/l-series-timing-chain-tension-retainer.html Quote Link to post
datzenmike 38,406 Posted May 17, 2013 Report Share Posted May 17, 2013 Don't cut the timing chain wedge to the dimensions above. It doesn't fit. I tried it.... Ill have to measure mine when I get home. 1.5 inch on top, 1.25" on bottom IIRC.... It fit snug and perfect all the way down. I will have to measure length. This is right out of the FSM. Quote Link to post
raggmann 43 Posted June 20, 2014 Report Share Posted June 20, 2014 mklotz70, is it the same dimentions for an L16 ? How thick should it be? Thanks, Quote Link to post
Sealik 396 Posted June 20, 2014 Report Share Posted June 20, 2014 3/4" thick There are 2 different wedges.... 1 wedge for all L engines..... and 1 for the Z series Quote Link to post
mklotz70 3,211 Posted June 21, 2014 Report Share Posted June 21, 2014 Sorry for the delay. Yes....I've used that exact same one on my L16s. Thanks for jumping in Sealik 1 Quote Link to post
