naughtydaughty Posted March 8, 2012 Report Share Posted March 8, 2012 I have a nikki carb on a 1300 cc engine and I dont know the mixture levels and it is rough starting and idling at times Quote Link to comment
naughtydaughty Posted March 8, 2012 Author Report Share Posted March 8, 2012 need help trying to find correct mixture levels for my nikki carb on my 1300 cc engine in my datsun pickup Quote Link to comment
wayno Posted March 8, 2012 Report Share Posted March 8, 2012 Do you have a window on the front of the carb with a line on it like this photo? 1 Quote Link to comment
naughtydaughty Posted March 9, 2012 Author Report Share Posted March 9, 2012 yes i do and it reads level.. Quote Link to comment
ggzilla Posted March 23, 2014 Report Share Posted March 23, 2014 Great. You have the right carb. When setting the idle mixture on any carb, start with the float level. The great thing about Datsun carbs is they include the sight glass, so the fuel level can be checked at a glance. With the engine running the fuel level should be within 1mm of the line. If not, the float must be adjusted as the level affects the mixture. Next, warm the engine fully. Ensure the choke is off Set idle speed to 700 rpm Turn mixture screw out (anticlockwise) 1/2 turn at a time until engine runs slower. Turn mixture screw in (clockwise) 1/2 turn at a time until engine runs slower. Then back it out slightly until is runs fastest. Engine may now be running too fast. Reset idle speed screw for 700 rpm. Adjust mixture again. You are done. Quote Link to comment
