MicroMachinery Posted November 7, 2012 Report Share Posted November 7, 2012 Drat. I was going to say to pull out those old soft plugs before painting it. If the paint hasn't cured, pull em out, otherwise the paint will crack. Brass soft plugs always look nice B) Quote Link to comment
Draynor Posted November 7, 2012 Author Report Share Posted November 7, 2012 MMM that looks good! Hoping to get my valve cover powder coated gold to match the soft plugs and wheels. Quote Link to comment
H5WAGON Posted November 8, 2012 Report Share Posted November 8, 2012 Popped out the side ones and rinsed out the block today, the plugs were not rusty. Always good to change while its out but they were good. The Brass will look nice. Twisted the dip stick tubes, they will come out easy. Check ebay Derek maybe a brand new one.. B) Don't worry Derek there is one more plug behind the Flywheel I will let you do along with the rear seal. Then paint the back plate....going to look nice. :geek: Quote Link to comment
H5WAGON Posted November 8, 2012 Report Share Posted November 8, 2012 Yes....The temp freeze plug got pulled also...Step by step it will be in. :thumbup: Quote Link to comment
Draynor Posted November 8, 2012 Author Report Share Posted November 8, 2012 Sweet! Quote Link to comment
H5WAGON Posted November 12, 2012 Report Share Posted November 12, 2012 Freeze Plugs in!....waiting on Gaskets, clutch hose and foot pedals... :frantics: Plus we get the added fun of doing this outside.. :baby: It should be installed in the next two weeks. Oil filter from my Volvo jumped in for a photo opp.....And we got the intake/exhaust gasket surface all cleaned up also. Quote Link to comment
Eagle_Adam Posted November 12, 2012 Report Share Posted November 12, 2012 lookn good man! Quote Link to comment
Draynor Posted November 12, 2012 Author Report Share Posted November 12, 2012 Thanks man! Quote Link to comment
H5WAGON Posted November 27, 2012 Report Share Posted November 27, 2012 Got some work done once it stopped raining. Capping off the old dip stick hole... Will try and find a hex....set screw to fit in flush. Front cover off....we decided to pull the head. Bam! Broke a Head bolt, while removing...2nd to last one....I did warn Derek this could happen. But it came out easy... B) Head gasket was iffy in a few spots...Cyl.#l1 & 4 So taking the head off was a good thing. Derek was like WTF!!! Lets just get these wheels on!!! n n Quote Link to comment
Draker Posted November 27, 2012 Report Share Posted November 27, 2012 You sir...... got lucky!! 1 Quote Link to comment
hobojobo Posted November 27, 2012 Report Share Posted November 27, 2012 needs moar low Quote Link to comment
yenpit Posted November 27, 2012 Report Share Posted November 27, 2012 Nice build! Don't know if you've researched this yet, but I went thru it with my 71 4dr auto-to-manual swap. Here's a quick re-wire for to bypass the auto nuetral safety switch, and how to wire up the reverse lights............. http://community.ratsun.net/topic/45721-510-auto-to-manual-reverse-lights/ 1 Quote Link to comment
Draynor Posted November 27, 2012 Author Report Share Posted November 27, 2012 needs moar low That it does... Quote Link to comment
Draynor Posted November 27, 2012 Author Report Share Posted November 27, 2012 Nice build! Don't know if you've researched this yet, but I went thru it with my 71 4dr auto-to-manual swap. Here's a quick re-wire for to bypass the auto nuetral safety switch, and how to wire up the reverse lights............. http://community.rat...reverse-lights/ Yep,got that covered. Thanks man! Quote Link to comment
banzai510(hainz) Posted November 27, 2012 Report Share Posted November 27, 2012 since you got the motor all the way apart mostly you can take the wood timmin chain wedge out and replace the tension ect and slack side guide(at least those 2 things.) lookong at the photo above it that tension can be pushed in alot more by adjust the slack side guide so it pushes the tensioner in more. watch this ,also on youtube PS is that a truck oil pan cause it dont look like a 510 oil pan that needs to be on there. rememeber to prime the oil pump PS I like this wagoon!!!!!!!!!! 1 Quote Link to comment
H5WAGON Posted November 27, 2012 Report Share Posted November 27, 2012 Waiting to use his L16 pan & pickup tube when we pull the motor... B) I had to mark the chain,,,,so I left the wedge in (Good eye on the guides) I will make sure its all snug before I close it up. We hope to put this in this weekend.....need to roll over to a friends house to get the Weber 32/36. Quote Link to comment
Draynor Posted November 30, 2012 Author Report Share Posted November 30, 2012 Got the head and the timing cover back on. Making good progress with our limiting time (and weather), but Its going to be in this weekend!!! :D Quote Link to comment
Laecaon Posted November 30, 2012 Report Share Posted November 30, 2012 Nice build! Don't know if you've researched this yet, but I went thru it with my 71 4dr auto-to-manual swap. Here's a quick re-wire for to bypass the auto nuetral safety switch, and how to wire up the reverse lights............. http://community.rat...reverse-lights/ Between me (who posted that fix for ya!) and H5wagon, we have him covered, as he is local to both of us. Quote Link to comment
H5WAGON Posted November 30, 2012 Report Share Posted November 30, 2012 Yeah, right after we got the head and front cover on it started raining. We are doing this all outside.....RATSUN, Don't give a SHIT! Quote Link to comment
H5WAGON Posted November 30, 2012 Report Share Posted November 30, 2012 Also a big thumbs up to Wayno for the head bolts! Derek is learning meaning of a direct swap....its all the little things. ;) 1 Quote Link to comment
Laecaon Posted November 30, 2012 Report Share Posted November 30, 2012 Also a big thumbs up to Wayno for the head bolts! Derek is learning meaning of a direct swap....its all the little things. ;) L20b is not a direct swap. L18 is. Also the auto to manual at the exact same time throws a few wrenches in. Quote Link to comment
H5WAGON Posted November 30, 2012 Report Share Posted November 30, 2012 Well almost.... :) Just enough to make him say WTF? I'm having a good time helping him out. Quote Link to comment
banzai510(hainz) Posted November 30, 2012 Report Share Posted November 30, 2012 Why you have the crank case vent hole plugged wiith the expandable rubber plug ??? PS You better open up the crank case vent HOLE!!!!!!!!!!!!! at least open vent it if you not going to use a PCV system. Quote Link to comment
Draynor Posted November 30, 2012 Author Report Share Posted November 30, 2012 Little set back.Was supposed to pick up a Weber today, but that fell through. Looks I am running the hitachi for a little while. Damn. Quote Link to comment
Eagle_Adam Posted November 30, 2012 Report Share Posted November 30, 2012 my buddy has a brand new 32/36 FS - PM me Quote Link to comment
