Busta Nut Posted June 1, 2013 Author Report Share Posted June 1, 2013 After finding the leak.........I decided to finish up the wiring. I was pressed for time AND my camera battery died so a lot of progress did not get oiced. All the alternator wiring, wiring the electronic ignition, wiring the starter, cleaning the fuse box, installing & routing the fuel system, making the battery cables......and everything else you didn't see in oics. This is where I left her last night....... 4 Quote Link to comment
Busta Nut Posted June 1, 2013 Author Report Share Posted June 1, 2013 Found some pics of the radiator install.....I bought a Champion radiator for it was cheaper than getting my OG one re-cored. It was NOT a bolt-in fit like I was told......spacers had to be made........fan shroud does not fit correctly either. Quote Link to comment
Busta Nut Posted June 2, 2013 Author Report Share Posted June 2, 2013 This morning I jetted the carbs and hooked up the linkage........put 5 gallons of 91 in her and left her on the Fast 420. The only thing left for the carbs is the throttle linkage.....haven't even given it thought yet. Quote Link to comment
Ranman72 Posted June 2, 2013 Report Share Posted June 2, 2013 I was thinking you left fast for the 420 :w00t: :w00t: not quite the same our club leader dave witt had the same problem with that radiator although it does cool good do a throttle cable if you can Lokar is the best dont buy Mr gasket cable shit it is SHIT 1 Quote Link to comment
Busta Nut Posted June 2, 2013 Author Report Share Posted June 2, 2013 Those Lokar kits look pretty cool......unfortunately I don't think I can get one before Canby. I'll have to rig something up....... I might have to run up there with a sway bar either, though....found the sway bar...found the endlinks and bushings....but no sway bar brackets and bushings..... .........NO idea where they could be :confused: ......of all the things I could've miss placed.....I guess that's not the worst. Might be askin someone to bring me a set to Canby if I don't find mine. :rolleyes: Quote Link to comment
Rollover_Red Posted June 2, 2013 Report Share Posted June 2, 2013 at least you guys get to go to canby....... :/ clean build! Quote Link to comment
Busta Nut Posted June 2, 2013 Author Report Share Posted June 2, 2013 Forgot to mention......... After I got all the connectors plugged in.....hooked up the battery......and pulled the headlight switch. I got chills seeing her open those eyes.......I fell in love all over again!! :wub: All my lights work!!! With the exception of reverse......(I need a switch for the trans....someone cut the wires flush). 1 Quote Link to comment
Busta Nut Posted June 2, 2013 Author Report Share Posted June 2, 2013 at least you guys get to go to canby....... :/ clean build! It's not running yet...... Quote Link to comment
Busta Nut Posted June 2, 2013 Author Report Share Posted June 2, 2013 Went to the shop for a minute after I put the kids to bed last night. I wanted to make sure the coil had power...................no power at the black/blue wire on the + side. I thought the coil wire is supposed to be black/yellow.....there is no wire that color anywhere near that side of the engine. Heading back this a.m. to continue the pursuit for happiness!!! 1 Quote Link to comment
INDY510 Posted June 2, 2013 Report Share Posted June 2, 2013 The coil wire should be thicker than most and is usually Black/white ... ... black with a white stripe The thicker Black/yellow is the starter motor wire 1 Quote Link to comment
Rollover_Red Posted June 2, 2013 Report Share Posted June 2, 2013 After I got all the connectors plugged in.....hooked up the battery......and pulled the headlight switch. I got chills seeing her open those eyes.......I fell in love all over again!! :wub: thats exactly how i felt when i got my Karmann Ghia driving again(couple days ago) i feel the love! 1 Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 OH GOD SHE"S ALIVE!!!!!!!! :w00t: :w00t: Took the kids to the shop for a few hours and just got back. She is running!!!!......needs all the fine tuning now. This space for video.. 6 Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 The coil wire should be thicker than most and is usually Black/white ... ... black with a white stripe The thicker Black/yellow is the starter motor wire Thanx Indy!! I figured it out......obviously. 1 Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 While at the shop today....even my daughter got in on this.... :thumbup: She helped me make a ground cable and pounded my dust caps on......start'em young!! ........BEST DAUGHTER EVER!!!!! :wub: 6 Quote Link to comment
r0p0doe Posted June 3, 2013 Report Share Posted June 3, 2013 Dude that's so sweet, I gotta get my lil girl to do that too but im afraid her moms turned her into a girly girl already -_- Quote Link to comment
the510keeper Posted June 3, 2013 Report Share Posted June 3, 2013 Kendall got to work right away.........and after breifly sanding the trunk.......she found a dead guy in it....... Yo that looks like the Misfits face Cool Your build looks great, keep up the good work, your almost there :thumbup: Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 Dude that's so sweet, I gotta get my lil girl to do that too but im afraid her moms turned her into a girly girl already :sleep: I brought her to the shop cause she likes to ride her bike around the obstacles.....yesterday she was very curious about what I was doing so I showed her. She makes daddy so proud!! 2 Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 Your build looks great, keep up the good work, your almost there :thumbup: Coming from you, that means a lot....Thx man!! ..............almost. Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 Last night I MacGuyvered the throttle linkage and made and installed the clutch slave line. ...........my senior quote couldn't be more true these days..... "If it weren't for the last minute........nothing would get done." 1 Quote Link to comment
r0p0doe Posted June 3, 2013 Report Share Posted June 3, 2013 I brought her to the shop cause she likes to ride her bike around the obstacles.....yesterday she was very curious about what I was doing so I showed her. She makes daddy so proud!! That's awesome dude, my daughter doesn't have to be a gear head but at least know the basics when it comes to cars and repairs, she's in her " I want to ride in daddys car & go faster" stage lol !!! Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 That's awesome dude, my daughter doesn't have to be a gear head but at least know the basics when it comes to cars and repairs, she's in her " I want to ride in daddys car & go faster" stage lol !!! That's great!! My daughter misses the Z.....she used to get excited cause she could sit in the front seat, it was low and loud..... ....now she want to work on it so we can drive it again......I told her the 510 is gonna be our new fun car so her brother can ride with us. She's not as excited because she doesn't get to ride up front but she is looking forward to not having a shoulder belt.......the things they get excited about :lol: Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 Started up and pulled her out to the front lot this a.m. Ran like shit.....fine tuning tonight......exhaust tomorrow..(guided everything with the DMV goes as planned) Here she is now.... Needs moar low in the rear.... 1 Quote Link to comment
Busta Nut Posted June 3, 2013 Author Report Share Posted June 3, 2013 Does anyone have any good tips on breaking in an engine?? Would the drive to Canby be a good break-in for it?? :confused: :confused: Quote Link to comment
Eagle_Adam Posted June 3, 2013 Report Share Posted June 3, 2013 come a long way man!!!! hope to see you at canby 1 Quote Link to comment
