thor Posted February 27, 2012 Report Share Posted February 27, 2012 Those of you with 320's. If you could buy tubular control arms to replace the king pin with a hardbody spindle (drop or stock) would you be interested? I'm shipping my stock setup to McClarys Metalwoks in Alabama to get tubulars made. Now I'm doing mine to lay out so mine would be different but since he'll have the stock ones he might be able to make a bolt in replacement for the rest of you. If there's interest let me know and I'll run it by him Quote Link to comment
]2eDeYe Posted February 27, 2012 Report Share Posted February 27, 2012 There are arms available that do that (at least for the 521 and 620), so I would say yes there is a market. These may also work on your 320, but I don't know for sure. http://community.ratsun.net/topic/3283-upper-control-arms-v2/page__hl__%2Bbeebani+%2Bcontrol+%2Barm Quote Link to comment
Pacific coast Datsun Posted February 28, 2012 Report Share Posted February 28, 2012 I can vouch for Matts (owner of mc clarys) craftsmanship. Its top notch & quality is 10+. Quote Link to comment
Zeke- Aus- Li Posted February 28, 2012 Report Share Posted February 28, 2012 i just got the cando tube arms on my 320? with the 720 vented discs... that tucked an re6 in there nicely... Quote Link to comment
thor Posted February 29, 2012 Author Report Share Posted February 29, 2012 Cando doesnt make them for the 320. Which did you use? Quote Link to comment
wayno Posted February 29, 2012 Report Share Posted February 29, 2012 Cando doesnt make them for the 320. Which did you use? 320/520/521 LCAs are basicly all the same size, there are some seal differances, and small changes like the LCA bolt that holds them on, but in general if you decide to use 521 LCAs on a 320, you just need the 521 LCA mount bolt, the LCA itself, and the 521 spindle assembly with the kingpins, as far as I know the upper arms are all the same. So basicly what I was getting at is, if it will fit a 521 LCA bushing, it will fit a 320 LCA bushing, as they are the same. There is a guy on Ratsun that sells "lower control arms", that are setup for balljoints, I don't recall what spindles he sets his arms up for, but the upper arms are also made for balljoints, if I were to guess, I would suspect you could use late 720 and early hardbody spindles, and that would also allow the use of the 720/hardbody drop spindles for sale on ebay. If your deleteing the torsion bars, what are you going to use for the front springy part? Quote Link to comment
thor Posted February 29, 2012 Author Report Share Posted February 29, 2012 Air bags Quote Link to comment
Zeke- Aus- Li Posted February 29, 2012 Report Share Posted February 29, 2012 Cando doesnt make them for the 320. Which did you use? modded hilux arms to fit the 720 spindles Quote Link to comment
