mrbigtankers 521
mrbigtanker
  • Replies 7.1k
So truck turbo is all done. Will pick up on wednesday in the morning. When they pulled the oil pan though a nut was at the bottom, could be a rod nut. So now have to look at that before starting up on the my FJ in the truck now or strip it all down and get moving on the other FJ Im having all built to go fast on a trailer. stay tuned.
29770642218_b9807ba79a_k.jpgUntitled by raymond medeiros, on Flickr
28752549757_1554493460_k.jpgUntitled by raymond medeiros, on Flickr
28752549737_b6de12fb29_k.jpgUntitled by raymond medeiros, on Flickr
28752549707_5c0396d78e_k.jpgUntitled by raymond medeiros, on Flickr
Brought truck home today.Came out really good. Still got a list of things to do.
1 bottom radiator hose
2 throttle cable
3 return oil line for the turbo
4 Wire up the water pump
5 wire up TPS
6 Oil pan has a lot of sludge at bottom of pan, might be dirty from ITB's.
7 Needs to have a seat of the pants tune.
  I think that it.
Fastest truck on a trailer!!!  LOL
One thing I like about you Mr Tanker is you know what you can do mechanic wise and what you are not comfotable doing you take it to the pros.
Edited by Charlie69
I have the know how and OCD, but i have no patience. I get angry really quick.
On a lighter note
Got the Vacuum lines ran, plugged the water tank and got the radiator hoses re done. Tomorrow i need to drop the pan and investigate the oil and where this so called nut showed up from. Also need to custom make a new throttle cable, wire the water pump up, and few odds and ends and fuck it, Im going tho fire this bitch up.
1 bottom radiator hose- done
2 throttle cable
3 return oil line for the turbo- done
5 wire up TPS
  I think that it.
1 hour ago, mainer311 said:
Yo, I hope you plan on dyno’ing that trailer when you’re done with it.
So system is ready for up to, [I had it wrong] but 620 Hp on turbo and 750 on cooling system. My fuel system can support up to 550 Hp so I am going to shoot for 450-500 RWHP on new FJ being built. Tis one will be a 5 Lb's of boost engine. Still stout but starting to seep so going to take it easy until new one is done.
